Or just use self-tappers, or even velcro.
Just a quick tip that someone has probably thought of.
Good place to mount your antenna is to rivet a small flat steel plate to the top of your snorkel so the magnetic base can grab to this.
Justin
 Moderator
						Moderator
D3Jon has his stuck on the bonnet hinge(County),quite a good bond,I pulled it off to check.
All in all,good idea Justin.At least with the D2,it will stick to the roof
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
RF Industries do a CB antenna base with integral GPS antenna mount on it.
As I have a Colorado, they go to a 3m accuracy without the need for an antenna and the built in one is better than the external! My Garmin external mounts on a suction cup plate that I just stick inside the windscreen to make it look "techanogical" these days!!
