Results 1 to 10 of 15
Thread: Replacment footwell
    Jul 2007
    Replacment footwell
    After having a good poke about have found the passengers foot well has a bit of rot going on where the inner mud sheild bolts on. Just looking through a landy mag I saw that I can get a new foot well. Anyone know if that is just the alloy pannel in front of the seat box or the steel part that rivets on to the firewall? Does anyone in oz stock them or will it be ex UK.
    Cessnock NSW
    G'day All, Footwells are made of steel, and they are available from the usual suspects in Melbourne. The footwells are attached to the b/head by spot welds hope that helps cheers Dennis
    PS Some people just use an angle grinder and cut out the old and weld in the new using a mig/welder, so I suppose it depends on how original you want to keep it looking, and it would be easier to remove the b/head off the chassis too.
    Jul 2007
    Thanks for that just what I needed to know. I intend on getting it relicenced as its in fairly good nick otherwise and will need to go over the pits so not sure if a patch would let it pass.
    Jul 2007
    Have you got contact details for TUS ? I'm in wa and no joy with the google.
    Logan ( Brisbane)
    Quote Originally Posted by Randylandy View Post
    __________________________________________________ ______________
    Check with John E on the sight he has or is buying ? a set fro Melbourne for his Ser 3 abut $60 each plus postage and the Melb mob is pretty cheap with freight rates Quoted me $38 for rear cross member Melb. to Brisbane.
    Hodgo
    Four Wheel Drives in Box Hill, Melbourne. Probably also available from any other Landrover specialists (not dealers).
    Jul 2007
    Just removed the old foot well today was pretty easy just removed the guard and drilled out the old spot welds and poped it out. Just need to clean up some surface rust and wait for the new one.
    Devonport, Tasmania
    G'Day Randylandy
    Have you ordered the footwells?
    If you have could you provide the details and price? I have to fit a couple myself very soon.
    Cheers Andy.
    Jul 2007
    Yeah no problem. Not ordered it yet just trying to track some down now. Will let you know.
    Caboolture.Qld
    Page 30 latest catalogue from Melbourne lists footwells at $55 each Right or left hand....
