Results 1 to 9 of 9
Thread: wiring uhf, help!!!
    brisbane
    wiring uhf, help!!!
    okok i have a uhf want to install it but im haveing a few dramas
    i know i can use a cig lighter plug but is there another method .
    my old man said run it to a fuse under dash. but i have 2 wires + & -
    (red &black)
    i knows its a easy job but yeah i have no clue. any ideas?
    thanks
    Oct 2007
    What vehicle is it?
    SYDNEY -in the shire.....
    yep...you got it.....
    red to +ve......black to -ve or earth on the vehicle......
    and make sure the antenna is also earthed as it should be.......
    its very straight forward.......you can run it straight to the battery......
    but use a fuse for safety.....this way....you can always use the radio....
    irrespective if the key is in the ignition or not......
    Oct 2007
    Sorry, I thought you were asking more... I.e. how to run it. Then I re-read it.
    Melbourne, outer South East
    Guessing a Disco.
    Don't use your cigarette lighter plug.
    Are you able to run the red and black power wires through your firewall out to the battery ?
    Let us know if you can. We'll then help with part 2.
    Run the red(+) and black(-) back to the battery, put a 5A fuse in line with the red wire. Run the wires through one of the rubber grommets on the firewall.
    brisbane
    ok thanks i thought so.....
    thanks
    Jun 2008
    Shropshire, UK
    Is there any advantage/difference/preference in running the black wire to the battery -ve terminal, or running it to a grounding connection on the body/chassis?
    (will be installing my new UHF if/when I ever get the Disco back!)
    ..:: KIEREN ::..
    2000 Disco II Auto V8 - shagged
    Snapper Guest
    Quote Originally Posted by AussieAub View Post
    ..:: KIEREN ::..
    Run it to the Battery.
