View Poll Results: What engine and gearbox does your Disco 2 have?
Voters
105. You may not vote on this poll
  • TD5
    76 72.38%
  • V8
    29 27.62%
  • Manual
    23 21.90%
  • Automatic
    74 70.48%
Multiple Choice Poll.
Results 1 to 10 of 25
Thread: Discovery 2 Propshaft Failures
    David Hallworth Guest
    Guys,
    Final bit of help that I need to ask for.....
    If your propshaft has failed, can you please post answers to the following questions:
    1. Is your car a TD5 or a V8?
    2. Is yours a Manual or Automatic?
    Thanks in advance.
    Also, If you don't mind guys, can i trouble you to post the information as well.
    David.
    Tamborine Mountain
    David,
    I think this failure depends on k's ,extremes of off road use and time, raised?.AND wether the air con unit has been dripping on it.
    I voted, good poll
    May 2008
    Horsley Park, Sydney
    After hearing of all the problems with these unis, I replaced mine with greasable unis before there was a problem and grease the unis regularly - every 10,000kms or more ofter when wet. This has been in the vehicle for about 150kms now. (about 1 hrs work and under $100)
    Erich
    NSW SW Slopes
    Quote Originally Posted by Baffle View Post
    David,
    I voted, good poll
    Or if the vehicle is driven on muddy roads with hot unis...
    crl Guest
    Mine was eight years old with 110000kms on the clock when it happened. The water dripping from the aircon on to the hot UJ eventually washed all the grease out.
    Back of Beyond
    It failed in my old D2:
    1999 D2 TD5 Manual
    Failed in 2007 @ ~ 215,000 Kms
    Caught before any damage and fixed pronto
    I have already pro-actively replaced mine in my new D2.
    crl Guest
    I wish I was proactive.
    Brisbane,some of the time.
    Just had mine replaced done 65thou k,were ok,but wanted greasable before problem occurs.Also piped ac drain to one side.
    MickS Guest
    Quote Originally Posted by IceFyre View Post
    1999 D2 TD5 Manual
    Yep - '99 TD5 auto - just cracked 200k last week - caught it before it could do any damage.
    Williams West Aust
    At around 220000ks.Already was aware of the issue.
    No damage at all,picked it up before it failed.Must add I have a 2" lift that must add to the problem.
    Replaced with greasable uni joints that I belive should have been factory issue.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
