Results 1 to 10 of 12
Thread: cb vs uhf
    brisbane
    Smile cb vs uhf
    jusy curious to know what aulro members prefer cb or uhf. i have both but are insure which one to install, i dont want both installed.
    what are the benifits of both, compared to each other
    thanks/....
    CB = Citizens' Band
    477MHz FM UHF is CB.
    27MHz AM HF is CB.
    brisbane
    27MHz AM HF is CB
    i have both but im confused ...
    which is better?
    Both are good. Its just that UHF is the standard now days, though that will most likely change again too.
    Most people fit the UHF unit, if you have a need for the older style AM unit (e.g. mates also have them fitted) then by all means fit it.
    d@rk51d3 Guest
    Gotta love the old AM SSB set.
    Christchurch, NZ
    Exclamation
    Hmm,
    Same 'ere in NZ. UHF is the new 'standard', but HF is better in the hills PROVIDED it is set up properly with a well tuned antenna. And it is hard to get portables for 26Mhz (yes, that's what we use here). You guys are lucky as the Americans make loads of good portables courtesy of Radio Shack etc.
    UHF is good for line of sight communications. I have got 30+km from a 0.5w hand held. This was across a flat, tree less plain. In built up areas range is considerably less.
    HF is good for long range at the right time of day. I get many hundreds of kilometres form a 5w car unit. Antenna tuning is important.
    If you want to be compatible with the majority of people on the road, go UHF. If you want to have unpredictable (predictable a little bit) long range communication use HF.
    Aaron.
    brisbane
    ive istalled a uniden uh088 with a 6db ariel.
    just wondering how u actually tune them???
    Free Again Thanks Dan
    Quote Originally Posted by glenn82 View Post
    You dont uhf is plug in and play
    brisbane
    i mean tune the ariel, it came pre tuned but how do u re tune, if need.
    dont know how they get out of tune////
