Results 1 to 10 of 12
Thread: D2 factory flares on a D1?
    Will it fit? I'll admit, the look I'm going for is this, Jupiter Rover's D2 from landroverforums.com:
    If so, any idea where I'd get a hold of some in Victoria?
    MSkinner,
    The wheel arches are completely different, the radius wont match up (already tried) & the plastic is pretty firm & wont allow for heating up & the re-bending to fit.
    The problem i found was the right angle peices that stick under the guard didnt match & were a pain to try & modify.
    But just thought if u cut then off it may sit where u want. Just an idea though.
    Good luck,
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    D1 wheel arches are smaller and different shape so you would be better off finding some d1 rubber flares, we have some (not for sale)
    CHEERS TIM.
    Jimboomba, QLD
    The fronts can be made to fit with a bit of careful cutting, but the rears will require a lot more work. I have a set that Scouse donated to do exactly what you are suggesting with my D1. I haven't got to the point of trying to fit them yet.
    The biggest problem is the profile of the D1 is different to the D2 and while they look similar, there is quite a bit of difference.
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    Well there you go...I didn't know D1 flares existed. I do like the bigger, fatter D2 flares, but if the radius is different then I already know that's going to be too much work modifying it for myself.
    Is there anything aftermarket that look similar without the big bolts running all along them?
    Oct 2007
    Here's our rubber ones on the d1 running 31/10.5/15 with 2" lift in the rear (still miner rubbing a slight guard trim would fix this)
    CHEERS TIM.
    Apr 2007
    Dayboro
    Quote Originally Posted by awabbit6 View Post
    Would you be interested in selling them (for my D2), you could put the money towards finding a D1 set for your D1 (no modifying)?
    Matt.
    trailworld Guest
    MSkinner ...
    Yes they will fit, need to work on it, but it's possible....
    Mar 2007
    South Coast NSW
    They look pretty similar to my std d1 flares. Mine appear to fibrglass.
    D1s have rubber or plastic standard flares - both have cutouts for the rubber anti-bump strips along the sides - the earlier D1s have wide antibump strips and the updates gave narrower strips - so if you get D1 flares you need to know whether to get plastic or rubber and work out whether you have narrow or wide bump strips.
    h
    This is a pic of my old disco with the plastic flares and wides strips.
