Results 1 to 8 of 8
Thread: D1 300tdi oil cooler pipe 'O' rings
    Geelong, VIC
    Are the O rings that seal the oil cooler pipe to radiator joints anything special or can I just get some generic ones.
    If so does anyone have a size? Mine were mangled when I removed them so I cant use as a sample.
    Steve
    NSW far north coast
    I'm pretty sure I have the correct one in my hot little hand and it measures 7/16"ID, 9/16"OD, section 1/16"
    Material.
    IMO it's better to have Viton or flurocarbon to handle the temps as Nitrile really has an upper limit of 135*C according to my book. (although I haven't seen an oil temp above 110*C yet, it's still only cool and I've only been logging temps a few weeks)
    Hopefully Tombie will drop in as this is his territory.
    Geelong, VIC
    Thanks Rick.
    I dropped into the local bearing shop at lunchtime today and picked up some high temp ones - Viton rings a bell - they are a slightly red/brown colour not black.
    The sales guy seemed quite switched on - I gave him the pipe dimensions and he came up with an O ring to suit. I'll check the dimensions against yours to be sure.
    Jul 2007
    rick130,
    Is that section measurement a radius? if diameter then we have lost 1/16 between ID and OD.
    Geelong, VIC
    Seems to add up to me. 7/16 + 2x 1/16 = 9/16
    Steve
    Jul 2007
    So it does. I work much better with pictures
    NSW far north coast
    Quote Originally Posted by slug_burner View Post
    rick130,
    nope.
    7/16 + 1/16 + 1/16 = 9/16
    Jul 2007
    Melbourne, VIC
    Viton o'rings
    Quote Originally Posted by steveG View Post
    Steve
    Viton (flurocarbon elastomer) o'rings from most auto shops ie Bearing wholesalers and also Pirtek, Enzed etc. These handle higher temperatures.
    L/R Part No is ESR1594L
