Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 119
Thread: The 4BD1 Part Numbers Reference
    Apr 2002
    Bellara 4507
    32.43 MB
    4 Speed clutch plate
    Code:
    AYG3616
    5 Speed clutch plate
    Code:
    AYG3463
    Turbo motor pressure plate
    Code:
    8970317592
    Non Turbo motor pressure plate
    Code:
    5312200240
    Throwout Bearing (4 and 5 speed)
    Code:
    AYG3339
    Input shaft bush assembly
    Code:
    AYG320
    120amp Hitachi Alternator with Vacuum pump
    Code:
    It is an HITACHI - AEA branded part number is ALT160502
    Code:
    120Amp 12V 'N' series. QLD branch (07) 3277 4566
    Starter Motor 4BD1 (T) ex AEA
    Code:
    OEM ADF unit (Labled as 12V 11T 40mm Mitsubishi)
    advertised as waterproof: ASM1670006, very expensive!
    Denso unit (Labled as 12V 11T 40mm Isuzu ARMY Denso)
    water sealed, wet clutch: ASND6055, approx quarter the price of above.
    12V alternator bracket on FFR and Civvy with A/C suit Hitachi
    Code:
    AYG0427
    28V Alternator and Civvy A/C model belt idler/adjuster bracket without pulley
    Code:
    AYG464 very expensive
    82deg thermostat
    Code:
    isuzu part number 8-94472331-1
    thermostat o-ring
    Code:
    isuzu part number 8-94176031-0
    don't replace the thermostat without replacing the o-ring
    Air Filter
    Code:
    Housing: Donaldson FH003-0429
    Main Element: Donaldson P90-0433 Main Element
    Safety Element: Donaldson P90-0434
    Fuel Filter Element
    Code:
    Ryco R2411PA
    Spin On Fuel Filter
    Code:
    Fleetgard FF5030
    Oil Filter Element
    Code:
    Baldwin P266
    Spin On Oil Filters
    Code:
    Full Flow:
    Ryco Z333
    Fleetgard LF3522
    Bypass:
    Ryco Z155X
    Fleetgard LF3523
    Water Pump to Thermostat Housing Bypass Hose
    Code:
    Isuzu p/n 8-94146297-0
    Code:
    GM 94146297)
    Water Pump Rebuild Kits:
    Code:
    4BD1     water pump kit 8-94473332-0
    4BD1T   water pump kit 8-94310477-0
    Flywheel
    Code:
    512330-0560 - PV type for generators
    894135-2140 - PA type for farm tractors (MT7300)
    894131-0620 - TPA type for hydraulic excavator
    894343-0492 - flywheel the Army use
    512330-2190 - P04-05 type for hitachi UH053 excavators
    894129-7160 - PY1 for hydraulic excavator
    894406-7540 - PTH/PH for hitachi ex120 and ex100 excavators.
    Engine Mounts
    Code:
    LH Eng mount
    Isuzu part no: 5532150320
    Don Kyatt no: 2Y3112
    RH Eng mount
    Isuzu part no: 5532150310
    Don Kyatt no: 2Y3111
    RH mount rubber cover
    Isuzu part no: 9532196020
    Oil Squirter
    Code:
    Check valve/bolt: Isuzu part no. 8973296180
    Jet, oil piston: Isuzu part no. 8943196990
    Exhaust Manifolds
    Code:
    1984-1987 non-watercooled manifold part no. 8-94119292-6
    1988 onward water cooled turbo manifold part no. 8-94366247-0
    Accelerator cable:
    Code:
    NRC5494
    Same as V8 110 and 3.5 V8 Disco 1.
    Glow plug part numbers: (even though no-one uses them).
    Code:
    12 volt
    HKT PI-49
    NGK Y-904M
    BOSCH GPI-010
    Champion CH306
    Isuzu 8-94175158-0
    Volts 11.0
    Type SQT
    Code:
    24 volt
    HKT PI-50
    NGK Y-954M
    BOSCH GPI-021
    Isuzu 8-94135377-3
    Volts 23.0
    Type SQT
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Isuzu oil filters.
    Quote Originally Posted by clean32 View Post
    as an idea
    Has anyone swapped out there fuel filter for a spin on type.
    how did you get on with the plumbing and mounting etc
    Quote Originally Posted by Bearman View Post
    No problem changing them over from element to spin on. You just have to buy a new (or used) mounting plate, fits straight on and the pipes plumb straight into the fittings. Part number is 5132120700. All the earlier motors eg. Stage 1 and I believe some Countys had the element type filters on both fuel and oil. You can do the same with the oil.
    Mar 2011
    Adelaide
    yes i went to a truck wreckers ( has to be one that do isuzus).
    cost me $55 for the twin screw on adaptor. came from a 4be1 engine, ours is the 4bd1.
    then get spacers machined up
    simon
    May 2006
    Woolgoolga
    does anyone have the part number for the little tin dust cover plate that goes on the flywheel housing just below the crank?
    WA
    Does anyone have the part number for the fuel pump/primer assembly?
    Hay Point
    Quote Originally Posted by Dinty View Post
    G'day All, Does anyone here know the part number for the 4BD1 water pump kit, cheers Dennis
    I have one in the shed, I will check tomorrow unless someone posts it up before then.
    Cheers......Brian
    1985 110 V8 County
    Hay Point
    if it is the hand primer you are after Ben, the p/n is 8941311300
    if it is the whole primer/lift pump assembly the number is 8941327070
    Cheers......Brian
    1985 110 V8 County
    Geelong, VIC
    Or Bosch primer 2447222126 about $20 on ebay.
    Refer this thread: 4BD1 Priming pump
    Steve
    Prindy Guest
    Quote Originally Posted by cornbread15 View Post
    simon
    Hi Cornbread 15
    Would that wreckers have an oil cooler for the Landy Isuzu 3.9 model 4BD1. Year 10/1981. I've searched online and Isuzu main dealers and have had no luck so far. The cooler has corroded through . I'ts a shame really as have had vehicle from pracitally new and is in excellent condition for year. I live and prospect in Murchison region of WA, so do all bush driving and she has never let me down. This cooler fault is my own stupidity.
    WA
    Quote Originally Posted by Prindy View Post
    Hi Cornbread 15
    Try Soltoggio Bros in Perth - but beware they charge like a wounded bull. They had a few isuzus when I was there last.
    There may also be regional truck wreckers (Kal or Geraldton?) who can help? I have had good service on new parts from Goldfields Truck Power.
    5 Epis Street, Broadwood, WA 6430
    East WA, South Eastern WA
