Page 1 of 9 123 ... LastLast
Results 1 to 10 of 89
Thread: Well... My Story, My Replacement. Introducing my Landy
    Jock The Rock Guest
    Gday
    Well Im not sure where to start I wasnt sure whether to put this in the Rant section, or the Buildup section or the Introduction. So I put it in General Chat
    My story for this year has been an interesting one very up and down.
    To shorten it, it started out well. I play rugby and was up to peak fitness all set for the season. I got my licence first go. And dad leant me his Defender while he went New Zealand for three months. Which I ended up buying off him.
    Then nasty things started happening. I had a reocurring back injury, so i went to the specialist and found out I had a bulged disc in my back. No more rugby this season. Wouldve been my 7th year playing and 5th year playing for Tasmania.
    So time went on. I bought dads Defender.
    Then while working on a large sheep property down the midlands I was putting the bucket on the front end loader of a 90 HP tractor. Its a long story but it landed on my toes, breaking the big toe, dislocating the second, and snapping the tip off the fourth. I was in hospital for 3 days with risk of infection. And came out with 3 pins in my toes. For 6 weeks.
    This is what dropped on my toes. I think about 250-300 KG
    I was only talking to my physio the other day. (Shes trying to get some movement back in them for me, and requested a letter from the doctor who put them back together). Anyway the letter read at the end that I was about this far > < from having them amputated.
    So got them all fixed and I can walk again.
    Then the rear main seal went in the Defender. Had it fixed and was told Im up for a rebuild. So I took it down to Justin Cooper. Who told me the head was cracked, something solid had gone through the turbo, the crank was seriously flogged out and I was up for a new radiator. We had only had the car for probably 5000 ks so Im pretty sure the previous owner forgot to mention the minor mechanical faults
    After lots of money I picked it up a week later. (Turned out cheaper to put a new motor in). Drove it home, loving every minute of it.
    The next day I rolled it and wrote it off was an accident. (My dad told me even an experienced driver wouldnt have been able to save it). He looked at the skid marks. Noone was injured.
    Luckily it was insured and the company paid out. I ended up buying it back off them.
    It may not look bad but almost every panel from the doors back has a crease or dent.
    It tore me apart. It was still drivable but luckily it landed on the steering arm so had a bit of a toe in. I broke down when dad arrived to offer assistance. First time I cried in probably 5 years. My car was my identity really all my mates knew me as the bloke with the Defender. And many a day I spent in, under or on top of it working away making it just that little bit better.
    That was almost a month ago.
    It took me bout 5 days before I even smiled again. And I actually lost sleep over it. And still do. It replays through my mind.
    So after 3 weeks of thinking I made a decision. Well mum did. She was sick of seeing me depressed. I went down today and picked up my new Landy.
    Its the same as my old one. Just a year younger. A different colour and has 200000 less Ks.
    This thread will be my bulid up. Showing you all the improvements I intend to carry out. Hopefully this Defender will last me for many years to come.
    My plans are:
    Switch over the BF Goodrich M/T if they are ok
    Switch over the Air Compressor and Rear Locker and the rear Maxi Drives
    Switch over the TJM Bullbar and Sidesteps
    Have a new alloy roofrack made up
    Full alloy checker plate kit
    Tweak the fuel pump
    Maybe suspension upgrade
    Hopefully be finished by the end of next year. Ill be working all holidays non stop.
    So thats my story
    Thanks for reading
    I had to get it off my chest
    Safety Bay
    Here's a thought,the blue one has bent panels,rebuild it into a duel cab ute,alloy checker plate brush guards,set off 33'' silverstones mate then you would be grinning!!.I'd leave the white one alone,looks good. Pat
    Jun 2007
    Oatley, NSW
    Thanks for the story! And i'm sorry to hear about the misfortune you have had.
    Will keep an eye on what you get upto! Good Luck with it.
    Stirling
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    I'm glad your alright and i hope things improve for you, can't wait till you start working on your new defer
    CHEERS TIM.
    Logan ( Brisbane)
    Just keep smiling sunshine
    Jock, I think I would have sat down and had a good cry too with all the rotten luck you have had. Thats all behind you now and you are so luckey to have another Defender it looks great and I am sure every one one this forum will be waiting for updates as you get it up to your specs
    I will be home in Tassie next March I will try and catch you to say hello.
    Hodgo
    Jock The Rock Guest
    Quote Originally Posted by hodgo View Post
    Hodgo
    Thanks mate
    That would be great Im always to keen to meet members of this forum in person
    Im planning once I finish Uni or during my year off to hit the road and travel Oz. Ill have to take a Laptop
    Melb. Vic.
    What a story Jock - Glad your ok. Hopefully you've used up all the bad luck for the moment - The new defender looks like a ripper. Keep us posted on your upgrades!
    Kingston, Tassie, OZ.
    Just a bit more to add to the Saga...
    When Jocks original 110 turned up, we pulled the engine to inspect and quote etc and found a cracked/ previously repaired head(Coolant had corroded an injector solidly into the head, and was welling up and down the side of the head), a crankshaft with very little left of the thrust washers, end float so bad that when the clutch was depressed, the timing belt alignment would've changed, a knackered radiator, a turbo inlet turbine that looked as if someone had thrown a rock at it while spinning at max revs,etc etc etc.
    Enter a Donor 110. Also a hardtop, the SAME age, the SAME colour, with 150K on the clock. This vehicle I knew very well,(I had serviced it since infancy) was rolled on its side some 3 weeks previously while on holiday in Cairns, so we bought the wreck and shipped it back down here.
    Jock ended up with the engine assembly (complete), the bull bar, side steps, winch, and sundry other Items which was all fitted up and he was on his way. Driving like a 300Tdi SHOULD go, and no more drivetrain clunks thanks to some Trailing arm bushes and A frame ball joint etc.
    About a week later, I get the phone call telling of the incident, and was stunned. Both blue, 110 hardtops, similar age, both rolled, one on the left, one on the right. You couldn't read about it!
    I'm glad that no one was injured, and as Jock says he seems to be 'lucky in his misfortunes', if you understand what I mean.
    The new one is a beauty, 70,000km, very well cared for and has a great life ahead of it!
    Go the 110!
    JC
    Alice Springs
    I would have cried too. The bad luck's all behind you now though and you have a truly beautiful 110 there that would make many of us envious. 70000km! It must be the lowest mileage Tdi in existence. Enjoy it. And go easy on the chequerplate.
    Colac foot of the otways
    Hope you have more luck in the future.Nice looking 110
