Results 1 to 3 of 3
Thread: VBA textbox name property
    Guru needed
    I've got an Excel form with 10 textboxes named tbBox1, tbBox2, etc.
    In my VBA code I want to run a loop that looks through a sheet and when it finds a value, populate that value into tbBox1, keep looking and when it finds then next value populate tbBox2, etc, etc.
    What I'm after is a way to dynamically change the textbox I'm referring to instead of individually naming them.
    ie
    For i= 1 to 10
    MyName = "tbBox" & i
    MyName.Value = Worksheets("Stock List").Cells(j, Stock_Column).Value
    Of course, this doesn't work. Any ideas please?
    Yes there are a couple of ways, either use a switch/case statement based on the value of i to direct to the correct object or use the translate object name (can't remember the exact syntax) based on "tbBox" & i to load the correct textbox for storing to.
    Don't have Excel at home now only at work, so can't look it up.
    Assuming the only text boxes on your form are the 10 text boxes in question then loop through the controls collection on your form
    j=0
    For Each cntl in Me.Controls
    If TypeName(cntl) = "TextBox" Then
    cntl.Value = Worksheets("Stock List").Cells(j, Stock_Column).Value
    j=j+1
    End If
    Next cntl
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
