Results 1 to 3 of 3
Thread: long range tank loose
    malsgoing130 Guest
    Hi All,
    I have been slowly going over my recently purchased 130 tdi, tightening replacing removing etc and have discovered that the long range tank has 2 loose mounting bolts on the rear cross member, were these welded in? because you would need a very specially shaped hand, arm and spanner to tighten. Does any one have advice on sorting this out without the use of a gas ax!!
    Malcolm
    99.87 MB
    If its welded.... Plasma cutter perhaps?
    Slunnie
    May 2006
    Townsville, QLD
    Malcom
    I fitted one to my 110 Cab Chassis http://www.aulro.com/afvb/projects-t...-big-tank.html
    I'm assuming that the 110 and 130 are the same from a mounting point perspective. If so, two bolts come down from the top through a bracket. The tank is lifted up into place and I can get a ring spanner onto the top of the bolts accessed from above. I then used a 12" extension on a long series socket to secure the nuts.
    Not sure if that helps.
