29th October 2008, 09:14 PM
Electric window short circuit
The passenger side rear window has not worked for a long time. I waited three months for a replacement driver's door master switch which I was assured would get it working again. And it did work for a couple of months. But now the dealer claims that a short seems to be blowing the fuse and the D3 will have to go to an auto electrician for a couple of days.
1. Has anyone experienced a similar window problem?
2. If what I'm told is true, then each window must have a separate fuse since all of the other windows work.
The car has only a couple of months warranty left so I would really liked to see the end of this issue.
30th October 2008, 11:13 PM
I found when I removed the door trims if I didn't connect one of the rear window switches back up, only that window would not work. It could be a problem with that switch or the wiring in the door or the motor.
Sounds like the dealer is not good at diagnosis.
