Results 1 to 10 of 24
Thread: 2008 defender 130
    Perth WA
    2008 defender 130
    Hi guys
    Ive done a bit of a search on the site but havent been able to find answers on a couple of things. Ive had the 130 on the road for 2 days and now Im wondering:
    (Sorry for the stupid questions I havent had a diesel before)
    Is there a speed limiter on these and if so can I get rid of it?
    Do tunit chips and the like really work and increase power without effecting
    fuel consumption? Im not a fan of magic black boxes for petrol applications but what about the diesel
    A lot of people have turbo timers and the like on diesels to let the turbo slow down. Should I idle the car before turning it off?
    The air intake is in through the side panel, it looks to me like sand from the front wheel would spray straight in as Ive got no front mudflaps. Anybody had this problem or hasnt the diesel got enough power to spin that hard on the beach?
    Ill try it out for myself next week anyway but any experiences would be good
    dmdigital's Avatar
    The 08 Defender can have a speed limiter but it shouldn't be fitted (activated) in Australia. Its referenced in the manual and shows where the indication light appears.
    Tunit and similar aren't the best solution and I doubt if they are available for the 08 Defender. Bell-Auto-Services in the UK does a switchable map for the TDCi ECU. As for what it does to fuel economy, don't know.
    Turbo timer is a waste of money IMO. Best thing is to slow down and just let the engine idle for a while after a long stint.
    solmanic's Avatar
    solmanic is offline One Merc post away from being banned...
    Maleny, Queensland
    No speed limiter on Aus spec Defenders Not that I've ever tried to find out the actual top speed mind you (Ahh - hundred and forty something - hem!)
    I can't see the benefit of chipping the ECU. The Puma runs like a chipped Td5 anyway.
    And I also wouldn't mess with a turbo timer. Many insurance companies won't cover your vehicle if one is fitted. It's seen as an unacceptable risk due to the fact that you effectively walk away with the engine still running.
    Jul 2007
    Eyre Peninsula SA
    Fit a Safari snorkle - essential in my opinion if the vehicle is going to be used off-road or even on road out side city limits
    Christopher
    Adelaide Hills - SA
    Quote Originally Posted by discokid View Post
    Had no problems with sand getting in the side mounted air intake and we've done quite a bit of beach work in ours.
    Diesel has plenty of power to spin in the sand. Don't reckon it's worth getting it chipped, but then there's no such thing as too much power! Straight from the factory they are a good balance between power and economy.
    Just got the dealer to fit the front mud flaps, and I have Mantec snorkel that I haven't got around to fitting yet ($500) ........
    dmdigital's Avatar
    While the wheels spin in the sand? Oh yeah! The Traction Control is fantastic though
    The side air intake is actually well protected and you don't get a lot in there. The main reason of the snorkel is to raise it for water crossings.
    Having seen Safari, Airtec and now Mantec on Defenders I would actually go with the Mantec. The Safari is IMO over priced as is the Mantec if you buy it in Australia. Cost me 50% of the Australian price to get one from the UK. Very easy to fit. The really nice thing with the Mantec is it's almost invisible from the driver's seat and doesn't interfere with the mirror. The Safari is a lot wider, sticks further out from the vehicle and still limits the mirror positioning. The Airtec is even worse.
    Perth WA
    Hi Guys
    Thanks for your responses thus far
    I guess Im used to my Gen 3 powered landrover and Ive always had v8s. They spray sand everywhere when working them hard and it gets in everywhere
    The diesel is a new thing for me
    The 130 doesnt have traction control but looks like a snorkel is the way to go anyway
    For what it is
    It is actually a well balanced car it terms of power and weight. Ill see when I throw my 3t trailer on the back of it how it goes
    Tunit chips are availiable according to Perth 4x4 here in Perth Im just not sure whether its going to give me that seat of the pants feel of power or not
    Ill probably just leave it alone
    Padstow NSW
    Quote Originally Posted by solmanic View Post
    you must be takin the ****?? or you had a very slow chipped TD5?? you wouldnt catch me in a pink fit
    cheers phil
    solmanic's Avatar
    Maleny, Queensland
    My point was more like - I had a regular Td5, and if I had it chipped and it went like the Puma, I would have been quite happy. Sure, there's no more power, but the ability to pull right through the rev range is just lovely.
    And sure, I wouldn't stand a chance against your weapon but then who would?
    Padstow NSW
    thats better! you may rise
    cheers phil
