 Originally Posted by
Mocky
				Hi All
I have a 300 Tdi and have found excessive wear in the timing case behind where the oil pump gears run. I understand that the oil pump gears are a replaceable part but am concerned at the cost of replacing the timing case. Has anyone had similar problems or is there any good second hand ones available.
Mocky
 Hi,
Was there an oil pressure problem? Can you post pics?
I have just been through this chasing a slow to go out oil lamp in a 380K 300Tdi in a 130.
This vehicle is a one owner, serviced EVERY 5K truck. I found deep scoring on the pump plate behind the gears, but not much actual wear at all in the aluminium housing of the timing case.
I replaced the timing case because although I could buy the gears, the plate is unavailable.(Thinking back, I could've probably refaced it, but it was quite damaged)
The oil lamp STILL takes the same amount of time to extinguish.
I am led to believe that these have to suffer some fairly horrific wear to actually cause a problem.
JC
