first of check that you havent fouled or miss aligned a linkage.
if you put the cover that helps insulate noise/heat from the cab in the wrong way it will fit but can give these symptoms.
Hi all, just a quick one, I hope. I'm finding it very, very hard to go from hi range to lo range. This has only happened since the remove/replace gearbox and t/case assy. Any ideas on how to fix eg: adjustments etc. Sorry, the veh is an 84 4door rangie auto. Many thanks in advance. Bob H
