Results 1 to 6 of 6
Thread: Nanocom - unable to init communication with ECU
    Oct 2007
    I've got the latest USB model nanocom and it's having problems talking to the ecu on a 2003 defender.
    I've tried the following
    • reloaded the 2.03 firmware
    • turned the ignition on, off, engine running and engine off
    • disconnected the electronic rust protector (apparently it can cause interferance)
    • checked the yellow cable is wired up correctly as per the FAQ page
    • did a test on the odb port with the display as
      01H 02H I1H I2H testing pins 4-5 and 8 I get 10v
      01L 02H I1L I2H testing pins 4-5 and 8 I get zero volts (as expected)
      01H 02L I1H I2L testing pins 4-5 and 8 I get 10v (not expected, should be zero volts)
    Can someone please run the obd test on theirs and tell me if you get the same results ? I am thinking that the high / low logic that the nanocom uses to transfer data between the ecu and the nanocom isn't working so this is why it cannot init the communication with the ecu.
    Duncan
    Not being flippant, but did you turn it on? There's no on/off switch per se.
    With the engine running, if you previously hit the lh button, try pulling the cable & reconnecting
    Or if you just plugged the cable in when running before, then try hitting the lh button.
    I find the yellow cable doesn't always connect properly as well.
    Max P
    Oct 2007
    Quote Originally Posted by Tusker View Post
    that thought has gone through my mind a few times
    I've thought along the same path and tried a few different variations, plugged in before I turn ign. on, plugged in after ign. on, plugged before and after engine on.
    Same result in the end.
    Oct 2007
    ok I've got it working now, if anyone has the same problem here is what I did to fix it.
    The yellow cable was wired up wrong, pins 7 and 8 need to be reversed, to test if you need to reverse them run the odb test
    01L 02H I1L I2H testing pins 4-5 and 7 expect zero volts
    01H 02L I1H I2L testing pins 4-5 and 8 expect zero volts
    Please note this is different to what is on the nanocom FAQ, I have emailed nanocom to let them know the data on the website is incorrect.
    I worked this out after we pulled the ecu and abs out to check the ground connections like what is suggested on the FAQ
    Jan 2008
    4510 QLD
    Quote Originally Posted by duncanw View Post
    Can you be alsolutely sure it's not a specific wiring reversal on your vehicle only? To elimate this possibility, another vehicle the same as yours needs to be tested. Maybe Nanocom are wrong, this has occured before.
    Oct 2007
    I'm 100% sure it's not the vehicle. I have the wiring diagram for the Defender and I was tracing the wires back to where they hook up to the ECU-ABS and the main ECU, and it matches as per the wiring diagram so I hope it's correct !
    I then put a multimeter on the pin which was supposed to goto the ecu while I was trying to get some data back from the ECU and I noticed that the voltage on the wrong pin was fluctating, this is how it tranfers the data so I resoldered the yellow wire to reverse pins 7 and 8 and it worked.
