Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: The Great LPG Swindle
    anybody noticed how the updated guidelines documentation from lpg australia, ostensibly liberalised with regard to state of registration etc, have also seen a couple of unrelated phrases deleted to further reinforce the monopoly of the industry to exploit this grant for their benefit and to discourage the private individuals the grant is aimed at ? until 24/09/08 the guidelines contained the following phrases:"Conversions using second hand LPG units are eligible to apply" and "If you do the LPG conversion yourself......."
    these references have now gone.
    what also appears to have happened is that these changes were not published on time. i accessed their site on 02/10/08, the day before my appointment with a fitter. and the forms and guidelines i downloaded were the older ones before the deletions.
    i had followed these previously referenced guidelines to the letter, bought some components used and some new, mounted all the major units onto my vehicle, made the preparatory electrical connections and then arranged for a qualified gas fitter to supply and fit all the high and low pressure lines, check all the components and commission and tune the system. i was invoiced $605 and the fitter signed my grant application forms.
    some 20 days after lodgement at medicare (it says 10 in the documentation) lpg australia (aka centrelink) refused my application for a grant. i have challenged them on this and they are squirming fit to bust and keep trying tricks to get me to go away. after reluctantly acknowledging my claim that the older information was all that was available to me at the time of the conversion firstly they tried suggesting that the line about 'converting yourself' actually refered to gas fitters converting their own cars. i pointed out that this was in the consumer guidelines as opposed to the dealer and installer guidelines so they put me on hold for 20 minutes while they thought about it, then came back with the suggestion, in full knowledge of exactly who fitted what, that i approach the gas fitter to alter the wording on the invoice to say "complete installation". whether they meant 'complete' as an adjective or a verb isn't known but as their denial of my claim has seriously screwed up my finances i was prepared to play the game. unbeknownst to me and in direct contradiction of their statement that they could have no contact with the installer direct, by the time i managed to get a call through to him 'somebody' had already put the fear of god into him and he wouldn't have a bar of it. his wife also called me a "dickhead" which was nice ! i suspect they had been leaned on because they'd seemed perfectly amicable previously.
    so now i've got to take up my case with the ombudsman, suffer the ignominy of applying for a hardship payment from an association i belong to <u>and</u> be insulted by people who've taken $600+ off me for about $400 worth of work.
    the only thing i've got out of it is a better installation than any pro would have done because i fitted things like a stone guard/heatshield to protect the vulnerable areas of pipework, a air meter flap opening device to prevent damage from backfires and used genuine rover type 'rist' heavy-duty soldered electrical connectors throughout instead of cheapo crimp ones.
    the single modification the fitter insisted i make to any of my work was to fit a second isolation point under the bonnet to allow the tank valve to be electrically disconnected remotely. he was happy enough with an inline fuse holder cut into the wire using crimp connections and cable tied to a convenient hook. as he is a member of the institute of automotive mechanical engineers who am i to question that for quality? oh, of course, i am but a 'dickhead'. that would explain why i have worked on ferraris , lamborghinis and jaguars professionally and have maintained trucks, buses and a myriad of other cars privately. i'm also an operational firefighter with plenty of experience in the hazards of lpg so the very thought of attempting anything in the slightest bit dodgy is anathema to me. at no time until the fitter made the gas connections and started the vehicle had any gas been anywhere other than in the s/h (in date) tank.
    i have since read that the ombudsman has forced lpg australia to reverse several refusals of the grant so there may be some hope yet. the stress my family and i are suffering in the meantime is immeasurable, just trying to keep our heads above the financial waterline because these clowns choose to spend their over-paid time trying to wheedle out of disbursing public funds to exactly the intended recipients. what is perhaps more galling is the apparent intention in modifying the guidelines to increase the chances that the grant actually ends up lining the pockets of the installers. i suppose i'd be drawing a long bow to suggest actual collusion but why the ACCC hasn't investigated the gas industry over their blatant over inflation of parts and installation costs yet is a miracle. how is a 'poorer' australian with a car worth sub $2k supposed to justify capitalising it by a further $3-$4k unaided ? these are precisely the people the government needs to target with assistance to reduce their emissions.
    i feel so duped by these events i am cancelling the solar hot water service we were going to have installed in a futher effort to reduce our emissions as i have no faith that the rebates promised by the federal government will ever materialise either.
    I think they are probably suffering from the fact that the number of applications was far greater than the expected number, so the scheme is way over budget, and they are trying anything they can think of to get the costs down.
    Same sort of problems with solar hot water, as you say (looked at this for my son a few months ago) and with solar power.
    And, as you allude, with the demand, costs of everything go up. When first announced, I looked at gas conversion of my 110, but found that costs had already gone far above the initial estimates, and there was a shortage of tanks, for example, so I could expect a long wait.
    Apr 2007
    Prospect SA
    Wow.
    Was that well written or what!
    What escapes me is are you asking for a bigger rebate than what you outlayed or are you just trying to get re-inbursed.
    I totally agree that since the gov incentive plan was introduced the cost of installation has definately increased and not just to cpi but to Installer price index. What-ever that is??
    I have had 3 done last 3 years. The guy I use does not charge excessive, he also offers to use 2nd hand parts and is a retired engineer and also puts heatshields, guards and all copper lines in.
    My last complete installation cost $2150 for a tripple scuba tank in back and a full tank of gas included is the re-tune after 2-3 tanks.
    Total cost $150.
    I feel for you and definately agree on how this is not helping the truly needy trying to reduce running costsend emmisions.
    There are however those that like to do their own install to save even more, get it signed off by a guy who will probably feels intimidated by a possibly superior installation and get same rebate and come out in front.
    Is that fair, well I don't know.
    Why not rty to re-apply for your total costs including the gas-fitters invoice and all the receipts you have for parts.
    This might not total the full rebate but at least you will not be out of pocket bar the time spend.
    Best of luck.
    mcrover Guest
    Im assuming here that you were expecting the $2500 rebate in exchange for the $600 bill that you put in..........It dont work that way.
    LPG Aust obviously havnt recieved a copy of your trade papers as a mechanic/mechanical fitter and LPG conversion endorsment......
    They then wont know if you are a capable fitter and eligable to getting the rebate.
    This is the reason they dont pay people to do thier own conversions, regardless of how well you think you have done the conversion they dont want to pay you to do it as the grants are to help people get their car converted buy a proven qualified and capable installer.
    As far as them making a huge amount of money off the parts, the conversion systems offered these days are a lot better quality than they were in the past as well as they are doing mostly vapour injection these days which is more expensive to buy and more labour intensive to fit which also makes it more expensive so the rebate has made the better gas systems affordable.
    Your old fasioned vacuum controlled systems (simple or complex) are not efficient, they never were but they were cheap and still are to fit but this is not what is normally quoted these days.
    The price of copper, electronics and tanks has also gone through the roof from their suppliers as well.
    I think your trying to rort the system a little (intentionally or not I dont know but no offense intended ) by reading more into the guidelines that is really there in reference to fitting it yourself.
    As far as the second hand systems go, I was told (and I am a qualified mechanic but not a lot of LPG experience these days) by a highly regarded (in Bayswater vic) gas fitter whom Ive known for 12 years that the only part of a second hand system that a good fitter would install would be an in date or retested tank but also fit a brand new AFL valve.
    Good luck with it.
    Im not surprised you were told to sod off buy the fitter, if you had taken about a grand out of my pocket I would have told you to sod off as well, I dont think he needed anyone to get in his ear.
    He had already done you a favour by signing off your work which is risky to his licence already if something was to happen and then you come in and ask him to lie to the governing body when they already have it on paper what has really happend..........that is called suicide, much like cutting off your own head or in his case canceling his own licence or at best being scrutinised over every rebate he puts through.
    Stop trying to get something for nothing as thats not what it is about, this is to help the very people that you are talking about but it's people like you who will ruin it for everyone because you think they should be paying you with our tax dollars for something that your not really elligeble for.
    Im sorry for the bluntness of this post but I think you need to hear it so you can look at it from another angle and maybe calm down a bit.
    Stress over this isnt really worth it, I know it's a lot of money but in the end it's only money, if you put your self and your familly under stress over a bit of money then your going to be up for a much larger cost.
    Definatly by all means push them to the letter of what they have written but be aware that things can be interpretted in different ways and the gov agencies dont do this just to pieve you off, they do it to protect all of our money which include yours.
    Mate have a beer destress and go back to work tomorrow and regain the money lost over the next year or so in the savings you will have by having your car on gas and have a good feeling that you know it is fitted properly.
    Yinnar South, Vic
    They don't need any paperwork from him, the install has been signed off by an approved installer, simple, its like roughing in your own house, you can do it, so long as you don;t make any final connections
    Majority of gas fitters are butchers, they do hideous things to cars on their installs
    Plenty of people have got the grant utilising second hand stuff, the bloke local here, who's does tank testing, is one of many
    Finding a fitter that will sign is where you did get lucky, they all think they're special here, because they have a licence to butcher peoples cars and won't sign off, even doing as you had, they make ALL final connections, you prep, so they don't, hack holes, tek screw everything, ruin your wiring loom...............
    mcrover Guest
    Quote Originally Posted by rovercare View Post
    Yeah I hear you there Matt, I had an XF PV years ago which we had converted (of course the boss went for the cheapest quote) and he put a screw through the fire wall and into the brake servo.
    He actually bypassed the saftey cut out the way he did the wiring and the tank was held in with hose clamps.
    The point I was making is they have a reciept which says that the fitter did the final connection and comisioned the system and if then they get paperwork saying something different and saying that he did the entire system for the same vehicle then all it takes is just 1 do gooder in LPG aust to do his/her job and that gas fitter has lost his business.
    Im not saying that he has done anything wrong with fitting his own system how he has but you cant have your cake and eat it too.
    In other words, he cant save money fitting it himself and using second hand parts and only spending $600 on having it signed off and expect to get the $2500 even though it may have cost him that much, they dont know that.
    It is a reimbursment not a payment.
    Yinnar South, Vic
    Quote Originally Posted by mcrover View Post
    I'm saying he should, its a one off, that figure payment, much like home buyers/builder, baby bonus, you fit LPG, buy/build a house, stick it in the missus and make a baby, you get paid $X
    So he's got it signed off, its all legite, so he should recieve the grant
    Nov 2006
    narellan, sydney
    go easy on him guys, He didnt say the total including parts was $600, he paid that to a gas fitter to get it certified.
    The other parts could have cost him another $1400, so i think he should be elligable for the full 2K.
    If they go and change the rules without notification, that is not on IMHO (but it may still be legal).
    Andy
    mcrover Guest
    In other words, he cant save money fitting it himself and using second hand parts and only spending $600 on having it signed off and expect to get the $2500 even though it may have cost him that much, they dont know that.It is a reimbursment not a payment.
    Quote Originally Posted by andrew e View Post
    Andy
    Isnt that what I said highlighted in Red.
    Im not meaning to have a go at him, Im just saying it how I see it.
    I get what your saying Matt but it's not the intention of the whole sceme from how I read it.
    I suppose it's an interpretation thing......again
    Yinnar South, Vic
    Yep
    But its a grant, not a reimbursement, remember at its inception, you could get a basic LPG set up for less than 2k and walk away with change, then all conversions went instantly to 2k+, it wasn't a reimbursement, according to the cost of your installation, but a grant of a fixed figure for fitting LPG
