Page 1 of 9 123 ... LastLast
Results 1 to 10 of 86
Thread: Another 120 project begins
    Adelaide, SA
    Smile Another 120 project begins
    What started as planning and preparation of my V8 90 for the Canning culminated with an Isuzu 120 sitting in my driveway.
    Needs a bit of work to get it roadworthied in WA, but very happy with it so far. For its 24 years of age, and 400,000 on the clock its in pretty good shape. I've only got a few pics, but will take some more on the weekend.
    In the transport yard
    Isuzurover's
    Next to its new sibling
    First impressions:
    - Great low end torque,
    - Gutless compared with the 3.9LV8 in the 90...
    ... I guess the first order of business is to look into turbo options
    Been trying to get up to speed on turbos by searching previous posts, trawling Garrett's Tech talk section and talking to isuzurover.
    Seems that a T3 Saab turbo from the 80's might be a good fit on a budget. A/R 0.48 on the turbine and 0.42 on the compressor & oil cooled journal bearing... for about $300, a good fit?
    What other options should I look at for up to say $700?
    Hay Point
    The T3 is a good combination on the Isuzu. I presume it it a 4 speed considering the age. Which is the best combination for these motors. At 400K the motor shouldnt be worn out but I would suggest a compression check to ascertain condition before turboing, they should be around 440psi. I put a 4BD1 with 200K into my 110 and turboed with a watercooled T3 and did another 550K with it before the compression started to fall off. In the end it only had 200psi and was still going good but lacked grunt on hills or when towing. You will be impressed with the difference. Good luck.
    Brisbane, Queensland
    Agree with Brian the T3 is a good option. T3's on SAABs had the low exhaust AR. T3s are the most manufactured Garrett turbo. However, T3 with small AR is not that easy to find. The T28 with a small AR like found on some imported Nissans is easier to find. The T28 has a similar compressor to a T3 matched with a T25 turbine. IHI is another possibility.
    As Ben found a new manifold is still available from Isuzu. I found Isuzu in Brisbane hard to deal with. There are several formats and they couldn't tell me which format they were selling me. So I didn't know if the one turning up was top/bottom or side mounted turbo.
    I used a GT28R which is a ball bearing version of the T28. I have been very happy. I paid $1100 new.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Yinnar South, Vic
    Where'd you find that?
    Adelaide, SA
    I've got a great deal on the manifold - Dougal posted a link to in isuzurover's Budget 4BD1 Turbo Install post.
    Was $160 US all up with postage (that's when the aussie was around the 0.8 mark).
    They come up on ebay all the time, here's a link to an identical one if anyone is looking for one.
    eBay Motors: NEW ISUZU NPR EXHAUST MANIFOLD (item 120330384720 end time Nov-14-08 09:12:00 PST)
    WA
    No pics of the astroturf Bojan???
    Rangier Rover Guest
    Good to see another 4BD1 120". Looks in fair shape. I like it in Red.
    I have a Turbo on mine. Still is not a rocket but nice and punchy to drive Keeps up with traffic no worries. Just lacks a bit in top end RPM. Hope to sort this soon.
    Tony
    Adelaide, SA
    Quote Originally Posted by Bearman View Post
    Ben took me for a spin in his newly turboed suzi and it goes great... put a smile on my face... almost comparable to the V8! .
    It's got the original 4 speed I believe and still going strong, except the CDL on the TC is not engaging - suspect vacuum line perhaps?.
    I've also got an LT95a mated to a 0.996TC to go in, but am wandering if it's worth the effort of swapping. What are the benefits of the LT95a over the standard LT95?
    Quote Originally Posted by rovercare View Post
    Central Coast NSW near brunswick heads. Accidentaly found it on country post while googling isuzu rovers .
    Will take plenty of pics on the weekend... , do you think I should pitch a tent up for extra effect!
    Quote Originally Posted by Rangier Rover View Post
    Tony
    Thanks Tony... it's OK externally, the chassis is amazingly rust free, and it comes with a few goodies hidden away (namely front and rear maxis, winch and long range tank under the tray)... might have been resprayed at some stage as the paint looks pretty good (or it could be that I washed it really well prior to handing it over to Autotrans).
    Could be a bit better internally (the instrument cluster is loosely hanging on by 1 bolt) but at least I've got easy access to all the wiring Has a few things that need sorting out (few electrical gremlins, leaky power steering, 30degree steering wheel play, warn belts, rusty wheels and well worn tyres), but nothing major so far.
    Impressed with the 4BD1 so far - it will quite happily run with a diesel leak out of the supply line (as I found out)
    What turbo do you have on yours?... and how do you plan on sorting it out for more top end power?
    Bojan
    Quote Originally Posted by Offender90 View Post
    When I had that trouble it was the (live) wire to the reversing light switch had shorted where the connector hat touched the edge of the air cleaner and pulled enough undone to short - the melted wire cut the vacuum line on top of the bell housing under the air cleaner.
    I think they are supposed to be more durable - I would not bother changing it if the case in there is good.
    Loose instrument cluster is probably a function of the tendency of the Isuzu to shake everything to bits, but also the plastic tends to disintegrate - you may have to replace it - they are not that expensive. Steering play is probably tie rod end or panhard rod bushes, but should be easy to track down. As far as the wheels go, note the recent warning on Sunraysia wheels.
    Bojan
    What I don't understand is with 120s as rare as they are, how did you manage to find a colour match to the 90?
    Adelaide, SA
    Some peopoe say I'm starting a 'red army'. - I strongly maintain it was more by sheer luck than by design.
    ... the steering play is in the steering box, so I'll be topping up the steering fluid first, then adjusting the steering box if play is still there, and if still there after adjustment, I'll take the box out of the 110 I bought from lewy110 (Greg) and put it in the 120.
    As for the CDL not engaging, it could be the same thing, because the revesing light has been wired up to a manual switch instead of being automatically switched.
    I did read the warning on sunraisia's but these are so far gone (heavily corroded at places), I'll be replacing them with a spare set anyway.
