youve got the wires on the gauge backwards OR youve got a flipped sender, pull the sender and put the float arm on the other way.
Righto time to ask the brains trust again.
my fuel guage works backward,
F= F/all
E= enough
Is it possible I have a positive earth sender in a negative earth vehicle?
I have even used the other side of the voltage regulator, the temp guage side to see if this changes, stays the same.
just asking before I fork out for a new sender or have I missed something.
What voltages should I have @ empty and full when measured at the regulator?
tried the wire swap on the guages. i'll pull the sender out tomorrow and check. Looking at it when i repaired the tank the sender looks as if it can only go in one way but I'll re-check I did the install and repair after an arvo shift could be the sleep monsters got me
thanks Dave
Unfortunately Rob, while there is no such thing as a positive earth gauge - the gauge and sender changed when they went from positive to negative earth in 1967. The senders and gauges are not compatible, and the senders work in the opposite sense. So you will get this effect by mixing the gauge and sender types.
There are two types of gauge - the earlier type operates by the repulsion of two coils and shows instantaneous changes in fuel level, and does not use a voltage regulator. The later type uses a thermal type gauge, same as the water temperature gauge, which moves only slowly, and has an external voltage regulator, which in the 2a is on the bulkhead behind the instruments, and on the 3 is on the back of the speedo.
Neither gauge is polarity sensitive, so the reverse reading can only be given by using the wrong sender with it. I'd have to have a look at the sender to see if it is possible to have the float set up to give reverse operation, but I do not think it is possible.
with the regulator on the bulkhead. 4 pins, 2 for the fuel, 2 for the temp. I'll post what I find even if it makes me look silly![]()
pull the sender out, the casting on the sender won't let the float rotate the other way, switched the wires again, no result. Double check earth circuit-extra wire from sender to body=same condition. i'll put up with it for now will borrow the sender from my brother-in-law's project. Still thinking toward positive earth sender. Will post result when i have tried the other sender.
Going back to my post of the 18th, you must have sender and gauge that do not match - could be either one is wrong, but if you have the instrument cluster with the temperature gauge, then it is likely that your gauge is the later one (which is correct if you have the cable operated wipers), since it is unusual to change gauges rather than clusters. Most likely the tank and hence sender has been changed for an earlier one.
think your right about the sender JD. previous owner was a fisherman and got sick of fitting landy tanks, hence the comodore tank in the tray when i got it.
So if the other sender fixes the problem there will be a pos. earth sender free to good home should anyone require it.
It is possible to convert the sender to work from one style of guage to the other style of guage. Take the top off of the sender to reveal the resistive coil. At one end of it, it will be connected to a stud which goes through the housing to connect to the wire which goes to the guage. To convert the sender, you need to connect the other end of the coil to the stud. Do not reverse the physical direction of the coil, as this will have no effect. You need to run a wire from the opposite end of the coil (from what it is now) to the stud.
You want to end up with a sender as follows:
Opposing coils guage (instant, early type)
Tank empty = min resistance (about 0 ohms) sender to earth
Tank full = max resistance sender to earth
Thermo type guage (slow to react, late type)
Tank empty = max resistance
Tank full = min resistance
I dont know if the guage will be calibrated very accurate if the reversal process is conducted, but at least the needle will swing in the correct direction.
Aaron.
