Results 1 to 10 of 19
Thread: County Brakes
    clean32 is offline AULRO Holiday Reward Points Winner!
    SA, Newton
    County Brakes
    OK
    I decided not to go to a second hand Defender diff with disks. mainly because of cost, not just the dif but then new disks pads etc. and there’s nothing wrong with the diff I have, new drums shoes, flanges, all seals good etc.
    Now my question is, I remember some one posting that fitting a disco booster was an easy job and it would lighten up the peddle. Is this so? Anyone done this? Any one know where the original post is? ( tried searching)
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    I do not remember that post, but there should not be a problem with pedal pressure on a County. If there is it probably means that either you have a vacuum leak, or the rear brakes are not working properly, probably because they are not properly adjusted - unlike discs, you can expect to have to adjust the drums every service.
    in the wild New England, NSW
    yes - adjustment procedure is very simple (2 shoes on each side) - its in the manual
    Just get an adaptor plate for a sals and run rear discs using County front hubs and calipers.
    There are one or two NSW members making up copies of the adaptor plates
    Kingston, Tassie, OZ.
    I have found that careful inspection of the rear shoe to drum relationship is paramount to a good pedal in a 110.
    The shoe thickness is critical if the drums are worn badly or are over max diameter, no amount of adjustment will help then. I agree with Dobbo, I would be still looking at converting to discs, as the county drums alone are worth a pretty penny each, and that still dosen't take into account the backing plate/ adjuster cams/wheel cylinder problems...
    Do it, it is worth it. Fitting the Defender pedal box, booster/ M/Cyl willl also be necessary, but the result is excellent.
    JC
    SA, Newton
    JC
    Second hand defender diff $1200, + new disks pads booster master cylinder = $2200.
    New drums and pads (matched) $260.00
    But you are correct that some attention is required to get the back brakes feel good, with out excessive pedal travel etc.
    Having said that I believe that drums on the back will last longer than disks on the back, and the cost of new disks is not cheep
    Quote Originally Posted by clean32 View Post
    Why are you buying a 2nd hand Defender Diff? All you need from it is the adapter plates $135 RRP each, Hubs discs and calipers can be got cheaply.
    SA, Newton
    Quote Originally Posted by dobbo View Post
    where, i was quoted for disks pads and calipers all second hand $800 or a replacement dif for 1200. and the disks look like thay were end of life or close to it.
    Freestyler Guest
    I have a Defender booster and master cylinder in my 85 county and it stops really well without much pressure on the pedal, I can even lock them up fully loaded. The only problem with the drums are there slow heat disipation. If your prepared to use the Gbox a bit and lay off the brakes the drums are fine. If you want to covert to disk all you need is Rangie raer calipers, County front hubs and defender caliper brackets. I am pretty sure 3mm is needed to be machined from these brackets to suit the county after that it all just bolts up.
    Tim
    SA, Newton
    Quote Originally Posted by Freestyler View Post
    Tim
    Defender booster and master cylinder, what year or are thay all the same.
    my county stops well, just would like to lighten up the foot for the Komandant, and then only for the one in a thousand panick stops.
