Results 1 to 4 of 4
Thread: Front springs on Puma aren't handed
    Yesterday I replaced the front springs on the Puma with LR HD ones (NRC9448 & NRC9449) which are handed. Standard fair on a Defender, driver's side is a tad stiffer/taller than passenger's. The originals on the front are both Yellow/Yellow marked which should make them NRC8045 or Front passenger's side springs.
    Not that it really means a lot, but I thought I'd post up this bit of trivia.
    Oh and as for the HD springs... front end is now back to what it was (just a little stiffer) before I added the ARB bar and winch
    And before you ask, I've already promised the old springs to someone else.
    Jul 2003
    Well that is interesting Derek because I think that mine has developed a slight lean to the driver's side.
    Mahn England
    Ex 300Tdi Disco:
    Check the paint markings if they are handed then should be white/white on driver's side and yellow/yellow on passenger's.
    I've just checked in the reference material I have and they list the codes for the front as Yellow/Yellow (NRC8045) for both springs on all the Puma 110's.
    I suspect they decided it didn't really mater if the springs weren't handed for the basic vehicle. Would probably shave a bit off production costs. Strangely the 90 and 130 are both still listed as fitted with handed front and rear springs.
    Padstow NSW
    they were tryin to save money on another colour
    cheers phil
