Results 1 to 8 of 8
Thread: 4BD1T - high-revving, shutdown problem?
    Singapore via Melbourne
    Hi guys, my 4BD1(after market T) decided on startup today to run straight up to the governor for about 1 minute and wouldn't shutdown, then shut itself off after about a minute (it's still on a pull stop cable while I'm living O/S *sigh*. My dad who was driving it freaked out a tad given he had not experienced such a thing before... not that I can say I have either!
    and before you ask, yep the problem didn't repeat after trying it again - started normally and shutdown as expected....
    ideas?
    I thought possible sticky throttle linkage, but he reckons it worked fine...
    Hay Point
    Sticky governor maybe
    Possibility of getting oil into the intake from the turbo bearings. If this is the case it is a very dangerous situation, and is only likely to get worse. The symptoms as described could indicate that oil is getting there after shut down, but not enough to be a worry while running (yet) - does it by any chance have an accumulator to keep pressure up to the turbo bearings after the engine is shut off?
    thanks guys...
    well I shall pass both of these back to the current driver to have a look - JD you might be right, it has done a lot of sitting around in the last 18 months, might not have even been started for a month or so. Any simply explained procedure to perform a check for this? or is it a demount the turbo job?
    I hope you are wrong and Bearman is correct though!
    Roverray Guest
    If it is cable throttle it could be simply a sticky cable after 18 months standing.
    Quote Originally Posted by EchiDna View Post
    thanks guys...
    Not sure how easy to do on that installation, but take the pipe from the turbo to the intake manifold off - if it was oil from the turbo the inside of this will be oily - it should have no trace of oil.
    Yinnar South, Vic
    Unless of course you've fed the breather from the rocker cover into the intake upstream of the turbo
    Roverray Guest
    Quote Originally Posted by rovercare View Post
    could well be right = I recently started a turbo phaser perkins engine that had been sitting a couple of years-- only 400 hrs total since I installed it new in a tractor for a friend. This was after I released a stuck turbo seal.
    When I got it going it had masive blowby but fortunately it vents to air not above the turbo. Has now settled
    mmm !! it would go well in a MK3 inter ---leave the underdrive - drive- overdrive box on the bellhousing == put in a 3 speed powershift ----
    must go to inter chapter and raise some bloodpressure
