more than likely the master cylinder, renowned for failing
some of the members get them sleeved with stainless steel
on/off road neither here nor there, its the number of clutch depressions
Has any body else had problems with clutchs.
my o6 defender has just left for land rover on the back of a tilit tray
according to racq the slave cylinder has gone.
Has anybody else had a similar problem or is mine a one off issue.
The truck has just done 40 000 K's and hasn't done much hard offroading, i would of thought that the clutch (slavve cylinder ?)should last considerably longer then this.
Also depends on operating conditions - humid or dusty weather will shorten the life, as will any hydrocarbon contamination of the fluid.
