Results 1 to 4 of 4
Thread: Running CB aerial cable in a Defender ?
    Bracken Ridge, Qld
    I have removed a cactus 27Mhz set from my ute, which was bolted to the rear of the cubby box. For the moment I intend to fit the UHF there, until I can sort an overhead console.
    At the moment there is a small hole drilled un the metal plate underneath the console, which has the power cord running through it. This hole previouslyu had the CB aerial cable as well (I had to cut the plug off to get it out).
    Given that the UHF cable I have is fully assembled... where would be the best place to run it ? Should I drill the exusting how out (would need to be a lot bigger in order to allow the plug the pass thorugh).
    Any and all USEFUL advice appreciated.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    cut the cable at the plug for radio end and one you have it in place bring it up here and i will solder it up for you
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    cut it and goto jaycar and buy a screwdown connector use that till you can get it soldered up properly OR like Ive done keep forgeting about it cause its still working properly.
    Bracken Ridge, Qld
    Ok so I ran it and it was all working fine until....
    I went to Carlovers and managed to snap the antenna (or rather the base of the antenna which seems to be a seperate bit but is, of course, not apparently availble seperately) off with the hose thingy. Sigh. A new one (with a spring base) is apparently about $130ish and has a different cable (attached to antenna) so I;d have to run one... again !
    Anyone have a spare UHF antenna that goes straight onto the standard GME type antenna socket at the bullbar ?
    Advice ?
    gone
    1996 Discovery 1
    current
