Results 1 to 3 of 3
Thread: Temperature sensor
    Temperature sensor
    I put in the new temperature sensor, same part number as the previous one (PRC4430).
    It works, but is looking a little hot on the gauge. The needle runs up through the white, and through the black and to just before the red bit starts.
    And sits there.
    Now I don't know if I've picked up the wrong sensor, or it is something else.
    Suggestions please.
    Simon
    WA
    When my guage started playing up, I swapped it for a VDO guage and sensor. Worth the $$$ - AND it has degree readings instead of just bars.
    Check that the gauge itself is properly earthed. If it is like mine it is earthed via a set of tags under one of the gauge mounting nuts, and this was loose.
    (actually my problem was with the fuel gauge, but same applies)
