saggy spring, weight of driver, what else is on that side, extra fuel tank? batteries etc
I have noticed a slight lean on the drives side, front axle, any thoughts on what could cause this???
no nothing on that side, none of the things you said, just noticed today, cant say its been like that before/
Well, you don't drive it from the passenger's side, do you?Many Defenders have this "issue" - and it is caused by spring sag as Pete said.
The front springs are, I believe, variably sprung from Left to right side, the driver's side being stiffer.
I'd say your spring has just reached a point where you might want to replace it or both with new HD ones.
2007 Defender 110
1993 BMW R100LT
Get ya fat bum outof the car and she won;t lean any more !
(Sorry couldn't resist!).
Juddy I have a pair of Front King Springs, if you feel like making me an offer. They are quite (read very stiff) and would suit if you have a lot fo weight up front - winches etc etc.
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
All the above
+++++ flat tyre
+++smaller size tyre on that side
or a hole in the ground
starting to run out of stupid stuff to put down.
Maybe the left side that is wrong?????????
on this note guys i was going to stick some new bilsteins all round (just cos really motors done 260,000) would it be prudent to wack on new springs too (keeping it standard ) as i am introducing a long range tank soon ....regards lardy
The rear twin coil (one inside the other) set up on 130's is actually very good - I wouldn't bother changing it unless you end up having to. Try it for a while and see.
gone
1996 Discovery 1
current
and what do a pair of front springs set me back?? oh and cant say iam fat...
maybe play on the front as the tank appears to be going under the drivers side ....on which all the sound deadening stuff under the seat boxes (chassis side) has nearly all come off should i try and get the rest off and replace it with new stuff or leave it ...all these things just pop in your head as you right it is an obsession now ...the mrs knows lol
