Thread: Diff Ratio's
    Dec 2008
    Central Coast, NSW
    Diff Ratio's
    G'Day.............
    I want to know where I might be able to find 3.9 Diff Ratio Gearing for my
    "2A",as I want to change it from the 4.7 thats already in it which is standard.
    OR if anyone has a better suggestion to get more speed out of it as I'm
    converting it to a 253 V8.Maybe the diff centre out of a V8 Landrover
    would do the job......would it fit.???????
    Much Appreciated.
    Tonestar.
    Free Again Thanks Dan
    Quote Originally Posted by Tonestar View Post
    G'Day.............
    Much Appreciated.
    Tonestar.
    Early Rangie 10 spline diffs 3.54 ratio will fit , no 3.9,ratio available that i know of
    Melrose SA
    You could use Range Rover Classic diff centres but the ratio is 3.54:1
    The rear diff in your vehicle is a bit light for its application so I would look
    at a set of diffs from a Stage 1 V8 (also 3.54:1) this will include the rear Salisbury that will not have strength issues.
    You could also put 60 Series Land Cruiser diffs in from memory I think they are 4.1:1
    East-South-East Girt-By-Sea
    1.20 MB
    A lot more to it than just changing the ratios.
    Rover 90 P4 cars of the 1950's had 4.3:1 diff ratios
    Rover 3 litre P5 cars of the 1960's had 3.9:1 diff ratios
    and everything was completely interchangeable with the (non-Salisbury or ENV) series Land Rover.
    Finding them will be your problem.
    I had a 253 (4.2 litre) powered Land Rover and you will find that the series box is not up to the task.
    Why go to all the trouble with the conversion and engineering when you can buy an off the shelf County or Defender with a 3.5 or 3.9 litre engine and change it to a 4.6 if desired.
    Diana
    99.87 MB
    You can the following ratio's new from KAM Differentials for Rover type diffs.
    Ratio overview
    4.75, 4.2, 4.1, 3.8, 2.83.
    4.11, 4.75 and 3.54 from Ashcroft Transmissions.
    I thought that Great Basin Rovers had 4.1 and 3.9, though nothing has changed in the last few years and their website is still not properly functional.
    4.7 from 4cyl and 6cyl series leaf sprung Landrovers, and 3.54 from every other front and rear beam axled LandRover.
    Slunnie
    I got my 4.7's from great basin rovers.. helpful & good service.
    Jeff
    Dec 2008
    Central Coast, NSW
    "THANX", to everyone who replied to my dilemma........all food for thought.
    I'll have to do a bit more thinking I think.
    Tonestar.
