Results 1 to 10 of 28
Thread: Engine conversion options?
    Dec 2008
    Ah well, flame time...
    As some of you will know, I recently purchased a '95 ES V8 which "seems" as though it might (or might not) have some issues. Firstly with rust, which I'm not "too" worried about, as it won't be driven much for a while, and will be garaged...The 2nd issue is a bit of knock in the engine, which I'm booked in to have diagnosed by the good people at Graeme Cooper automotive...
    If issue #2 turns out to be terminal, I'm a little concerned (read: scared ) at the cost of rebuilds for the 3.9s, and more than a little concerned that Rover haven't really sorted out some quite fundamental flaws in the design and execution of the engine in ??? years...The worry being that, if I spend $$$$ rebuilding it, in 100,000 kms I'm going to start hearing more knocks etc
    So, the question becomes whether it's more economical (or even remotely do-able) to put another V8 in there.
    If it were up to me (ie. I had the $$), I'd be putting a 1UZ-FE in there, as I've had some experience with these, and know them to be basically unburstable. They're also all-alloy, have 6-bolt mains etc etc.
    Problem is that, as a package, they're considerably larger than just about any pushrod V8 (we usually say that if you want to fit one, you need a 700x700x700 cube), and that for a Disco fitment, pretty much everything is on the wrong side, so more $ in custom lines and hoses etc, not to mention fooling the ECU into playing nicely with a manual transmission - unless one can procure a Crown halfcut, with it's separate ECUs for engine and transmission. I'm almost certain that no-one makes an adapter plate to mate these to the Landrover's manual gearbox...
    So, I got thinking about other, potentially easier options, such as the humble injected Windsor V8.
    Certainly, this all-iron lump will weigh a bit (lot?) more than a Rover V8, but as a package, it almost looks made to fit in an LR engine bay, with all ancillaries in comparable spots, throttle body on the LHS, narrow(er) bank angle (compared to a traditional 90-degree V8), and the pushrod engine's smaller packaging. I'd still need an adapter plate to mate up to the Disco's transmission, and somehow get the Falcon ECU to work in the LR *shrugs*, but apart from that, why shouldn't I consider it?
    Note that I'm only researching potential options at this stage, in case it all goes pear-shaped and I get the call from the people at Graeme Coopers that I'm dreading...We'd like to keep this car for a while (even though it will not be driven that often); I just don't want to forking out $$$$ every off year to keep it on the road...
    Yea, Victoria, Australia
    I wonder if the bellhousing on the 6speed ZF V8 OHC Falcons are the same as a Windsor 4 Speed bellhousing?
    Sounds totally different just by typing it!
    Maybe you could make one.
    Aug 2008
    perth w.a
    sorry to say
    but is it really worth all that grief i would get...... out sorry mate
    Yinnar South, Vic
    First thing is first, Budget? 2nd thing, how much can you do yourself? 3rd, what do you want to achieve?
    Foot of the Otways
    What Rovercare said . Might even pay to look around the wreckers and see if they have any complete running engines . Could be a cheaper option to get you back on the road .
    a quicky re build of the engine alone once you get it out and in for them shouldnt cost you more than $1500 if the block and heads are in good nick..
    thats not the same as a full rebuild but its usually enough to give the engine a second life...
    if you want the whole 9 yards, just how deep are your pockets?
    99.87 MB
    I'd put in another Rover V8.
    Slunnie
    St Helena,Melbourne
    4.28 MB
    Go find yourself a pre 64 big block buick/ pontiac donk, it will bolt straight in - failing that just get another rover short, they are pretty tough little motors.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    ACT
    why not a 304, bolted to an auto, adaptor to rover transfer, do this then let me know so i can attempt it later.
    mcrover Guest
    Money, Money, Money..........
    Engine conversions unless you can scrounge the parts and do the work yourself cost normally double what most people budget for it and then if it's to be sorted once it's in, probably double that again.
    I would rebuild the 3.9, there's nothing they dont know about these engines anymore and I think your fears of it blowing in 100,000kms wouldnt be true if it was to be built properly with good liners, flowed heads, decent cam etc etc, and if looked after properly will last indeffinately.....as with just about any engine.
    But in saying that, if you were to go the conversion path I would go the windsor as this is a tried and true package and there is plenty of info around about it but there will be a lot more to it once you start so be warned, things like sumps and oil pickups, engine mounts and exhaust routing are major hickups that a lot of people dont think about but like I said, there are people such as Matt (Rovercare) who could help out with info on this.
    I take it that Toymotor engine was the Toy V8......?
    Why not look at a Diesel conversion, you could get info from LRA on the TD5 conversions, Slot in a 4bd1t, go sick on a 300Tdi or jam a Chev duramax in there and hope for only cold days when your driving it
