Results 1 to 10 of 12
Thread: Stuck again & not happy Jan
    Alex Heads
    Well the Disco is not firing up, and I suspect it may the fuel pump. AGAIN!
    Since the other one was put in, it has not felt right, the gauge has been all over the shop, and never read anywhere near accurate.
    Anyway...about 2 weeks ago, spoke to the mechanics who said they would replace it, no charge, cause they've had a few with issues.
    Yesterday, I go to start the Disco and get nothing but cranking and the whining fuel pump from the back. Tried to prime, tired to reset, etc,etc.
    What else could this be?
    I called Mechanic and they are closed for 2 weeks, they tell me can't get ya a fuel pump, can't help ya. We're back in the New Year.
    Thanks a ****en lot ya jerks! Had reservations about them for a while now, which are now confirmed.
    Needless to say, I won't be going near them again!
    So, I'm up for another bill from somewhere else, and probably no car over Christmas. Not good & not happy JAN!!!
    mike 90 RR Guest
    Feeling for ya
    Who is the maker of this fuel pump?? .... Can't you fit a second hand unit in it yourself? ... then send the old / new unit back and demand a refund
    If it is the pump, just go to a LR dealer, buy a new one and fit it yourself. Its not too difficult.
    is it not law that there must be some sort of warranty on new parts?
    Dont even consider a second hand one
    Avoca Beach
    If the fuel pump is whining, odds are its pumping. It should just pump fro 3 seconds then stop until teh engine starts or you turn the ign off and turn on again.
    So it may be something else, or maybe you have just flooded it.
    First try to start holding your accelerator down fully, without pumping for about 20-30 seconds. If it starts you have flooded it which may be old drooly injectors.
    If not then maybe your immobiliser is crook or the ignition is faulty.
    Maybe push it out to the street and call the NRMA or RACV or whatever.
    Regards Philip A
    South East Tasmania
    Give a ring to British off Road on 07 5445 1094 they are not closing during the holidays.
    Feb 2005
    geez and i was going to ask you out for a drive over the next week or so....ever thought of buying a tdi, those td5's are so unreliable
    hope you are back on the road soon
    Avoca Beach
    Whoops I assumed V8.
    Well all a diesel needs is timely fuel, compression and valves that work, although the ECU in a TD5 is apparently like a V8 in concept.
    Regards Philip A
    May 2003
    On The Road
    Time to move sheds Fen,,,
    There has to be something OTHER than the pump wrong,,
    old news I know,, but with a change of mechanics maybe some new ideas!
    must be something,,,
    Alex Heads
    Have changed sheds Pedro
    It was the fuel pump, the previous jerks had some dodgy supply (probably cheap chinese copy) fuel pumps. They still charged top dollar for that and fitting.
    Now the blue starts to get a refund
    Meanwhile back at the batcave, need a few things replaced, like rear diff, transfer case, and a few other items. Would like to give a Belfast cracker to the previous mech's I can tell ya
    Jun 2003
    Launceston, Tasmania
    you need to replace the rear diff and the transfer case, and you were worried about the fuel pump
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
