may be dirty contacts or possibly damaged contacts
Can't see a tech section here but i need help please
My Nikon D100 has stopped registering lenses for the autofocus... can still manually focus and shoot but think my eyesight is going
Any ideas before i take it to a professional??? Oh and does it on every lens.
Outlaw
EVL '96 Defender 110 - Emerald '63 2a Ambulance 112-221 - Christine '93 Rangy - Van '98 Rangy - Rachael '76 S3 GS - Special '70 S2a GS - Miss B '86 Rangy - RAAF Tactical 200184 & 200168
Like Lou says, clean the contacts on the camera body and also on the lenses. Clean the entire mounting ring as well.
The other thing is move the focus switch around a few times between M, S and C.
What lenses are you using are they ones with a built in motor or that need to be driven from the camera. The early AF lenses (about pre-1990) had a screw like connector to the motor in the camera body. If its something like that then its off to a repairer or a new D300.
and take the battery right out, leave, re-insert.
But sounds like a repair job.
All the above suggestions worked with my D200. Upgrade the software if available
Is the Manual/Auto switch on the lense set correctly?
D100 has no firmware upgrades available. However, it may be worth searching the Nikon Knowledge Base website.
