you should try looking at the connectors on the indicators to loom section, ensure they are not corroded making a poor earth.
If it turns out to be the case just change them out for new parts.
i hope that helps lardy !
I think i have an earth issue with the 130 when i use the right turn signal indicator i get a increase in speed of the indicator whilst under braking any experience of this anyone ????? thanks andy
thanks mate,
I did what you suggested, and sure enough it was a connector that had corroded, i changed it out and what do you know it works fine thanks for your input lardy
That's not your only problem.
You've started talking to yourself.
And even worse your getting answers
CC
when i flick my indicator the trailer symbol flashes aswell???? any ideas? or same as above
 Master
						Subscriber
						Master
						SubscriberI believe it's supposed to flash once when the indicators are first used, if it continues to flash then the load on the indicator circuit is too high and the indicator relay thinks the trailer is connected. I had this in mine when I had a 20W indicator globe in the bull bar instead of 5W.
Sorted.
Glad we could be of assistance.
Simon
