Results 1 to 10 of 33
Thread: Swapping diff side gears from 24spline to 10spline
    Douglas Park, NSW
    It looks like I've lost another 10spline diff in my '87 RR on the weekend.
    I should have another spare diff which I can use (just need to dig it out)but I have several 24spline diffs from late D1s.
    I would like to convert my diffs to 24spline jobbies but I don't have the axles & hubs yet. In the meantime I would like to convert one to a 10spline as a back up diff.
    Is it possible to change over the side gears in the later diffs to fit the early 10spline type?
    Or am I just making life hard for myself?
    Over to the diff gurus........
    99.87 MB
    I really dont know the answer, but I would bet that it'd work. The planetary gears may have to go over also. It'd be intereting to try it while its out.
    Slunnie
    Yinnar South, Vic
    Just swap the crown wheel over on the carrier, depends on bearing sizes, they vary to
    99.87 MB
    Quote Originally Posted by rovercare View Post
    Crownwheel or sun gear?
    Slunnie
    Douglas Park, NSW
    I would like to use the late D1 carrier if possible due to the fact that the RR ones are now not much chop .
    Looks like I'll try the swap & see what fits (and what doesn't).
    99.87 MB
    Good stuff! Be interested to see pics if you take them too.
    Slunnie
    Bathurst NSW
    Hi Scouse, i remember when i did my diff up mt airlie that weekend and lokka helped me rebuild it we stuffed around trying to put a 24 spline hemishpere from CAL415's disco after he fitted the locker into a spare rangie classic carrier and the bearings were different so we couldnt do it. Not sure if the gears can be swapped over though.
    I would just whack the make do with the 10 spline spare you have and when you get the axles and stuff just swap over the whole carrier. Matt
    <a href=https://the4wdzone.com.au/wp-content/uploads/logo.png target=_blank>https://the4wdzone.com.au/wp-content/uploads/logo.png</a>
    The 4wd Zone/Opposite Lock Bathurst
    263 Stewart Street, Bathurst, NSW
    http://www.the4wdzone.com.au/
    Discounts for AULRO members, just shoot me a PM before you purchase.
    Bathurst NSW
    Or you could just get a locker
    Douglas Park, NSW
    I'm tempted by the strength alone of a locker diff being 4 pin.
    I'm not keen on having a locker though - I know it makes life easier but that takes all the fun out of it .
    I always think that fitting lockers starts to make you think you can go anywhere....hence getting yourself in to more tricker situations were your likely to break stuff. situations which you wouldn't normally find yourself with a reasonably standard car
    needless to say I would like one in the rear eventually
