Results 1 to 8 of 8
Thread: 245/75R16
    Oct 2008
    Newcastle
    245/75R16
    Im running 245/75R16's they are the standard steel rims, and i have a 2inch lift put in as well. I have not completely flexed him up yet but was curious do i have to cut the guards for these tyres to clear when i do flex it up big time?
    Cheers James.
    klappers Guest
    Take some photos!!! I would love to see it on full flex!
    Hobart
    Quote Originally Posted by Grover-98 View Post
    Cheers James.
    Yes. I found out the hard way.
    Pete
    2008 Range Rover Sport TDV8
    1973 Range Rover Classic "Suffix B"
    Oct 2008
    Newcastle
    Quote Originally Posted by klappers View Post
    Firstly i will cut the guards then i will flex it up safely as last time i flexed up a truck i ended up putting it on its side
    And ill get some pics!
    Hobart Tasmania
    heres mine, 245x75x16 with camel cut rear guards.
    Carlos
    1963 Land Rover Series 2a 88
    Bayswater North, Vic, 3153
    Cheers James.
    Yes.....
    .... now cut (and running 235/85-16 BFG MT's)
    Stevo
    Oct 2008
    Newcastle
    Oright so iv had a great mixed response some saying it will be fine others saying it will rub...id like to not cut the panel work mainly to save effort, but seeing ill have to do it what is the best option?
    James.
    Melbourne, outer South East
    You will get some rubbing on full flex if you don't trim some. It does not need to be much.
    It depends a bit on the make of tyre ( some more aggressive mud tyres with big side lugs will be worse ).
    You might need to adjust your front steering stops as well.
    However none of this is a big deal.
