Results 1 to 8 of 8
Thread: Itunes time out??
    Sunny Pucka
    Itunes time out??
    Hi everyone, this is Easo's wifey, I'm having problems with Itunes every time I try access the Itunes store it keeps coming up with
    Itunens could not connect to the Itunes store. The network connection has timed out
    I have tried to uninstall then reinstall the itunes programme and it still wont let me get into the store.
    Any suggestions?
    Thank you.
    Easo's wifey.
    Oct 2008
    Newcastle
    Just use limewire or one of them then you wont need to pay
    Quote Originally Posted by easo View Post
    Any suggestions?
    Thank you.
    Easo's wifey.
    Apples servers have been swamped in the last 7 days.. All the kiddies with iTunes cards, iPods etc...
    Leave it a while
    Dec 2008
    Brisbane Australia
    How long have you had the issue. I don't thinkit is apple as I can get through fine.
    It is most likeley that there is a proxy setting or firewall issue at your end.
    A good place to start is,
    Under tools in internet explorer, select internet options / then connections and then LAN Settings. Try unchecking every thing (take note of the settings first in case we need to put them back.)
    save it all and the open itunes and see if it works. If not then reply with what version of IE you are using and if you are using vista or XP and we can see what we can work out
    Quote Originally Posted by Tombie2 View Post
    Leave it a while
    Yep, I've had a couple of time outs too.
    Sunny Pucka
    no its been like this since before christmas...there is nothing checked in LAN settings already
    Oct 2006
    The Vines WA
    Happens to us quite regularly in peak periods (evenings). Christmas would have made it worse.
    As others have suggested, try the store at a different time of day or night.
    Sunny Pucka
    Fixed
    Right not to sure how my brother did it but it is fixed now. He said that it (proxy I think) was set on 'home office' and not external.
    Unsure what that means but the wife is now down loading McClouds daughters. AAAAAhhhhhh
    Cheers all, Easo
