Results 1 to 10 of 31
Thread: 300tdi on bio?
    Dec 2008
    pottsville (northern NSW)
    Post 300tdi on bio?
    would someone b able to tell me if and how can a 300tdi be converted to run on bio fuel, does bio still work with d/gas or diesel gas
    Oct 2008
    No conversion is needed on a 300tdi, just fill up with 100% diodiesel. There is a changover period as it flushed crap out of the fuel system so you will more than likely need to change the fuel filters in the first 1000 k's or so and keep checking them. The 300 tdi seems to run a lot better on biodiesel, makes it noticably quieter.
    I bought my biodiesel from SAFF which run a few servo's in melbourne that sell it at the pump.
    Dec 2008
    i heard somewhere dunno how true that it can eat away at gaskets and seals and stuff, but if it doesn't need no mods than thats the go.
    There is a possibility that if your fuel injection pump is getting long in the tooth that running biodiesel will speed that along. Rebuilding a fuel injection pump is quite expensive.
    Simon
    SA, Newton
    Bio good stuff, when i had my 300 tdi we run it on nothing else, no problems.
    just remember that bio is more of a solvent than dino diesel, so all the crap that has built up over the years in your tank and lines will break down and end up in your filters, possibly even blocking them. Its no big deal you end up with a cleaner system anyway.
    As for Gaskets, old days with rubber gaskets, they tended to dissolve or swell, the modern stuff no problems
    Just don’t fill up at Saff until after 830 am, you don’t want to joint the long Que of trucks filling up before they head interstate.
    SA, Newton
    Quote Originally Posted by abaddonxi View Post
    Simon
    Bolloxxx, the 300tdi is lubed by the motor oil, bio no efect
    VIC
    Simon
    Looks like you've been reading excerpts from my version of "this is your life"
    VIC
    Quote Originally Posted by clean32 View Post
    Umm no. It isn't a inline pump lubed by the engine oil. Its a radial pump lubricated by the diesel fuel.
    Only going on personal experience and hearsay. Several on AULRO, me included have found the need for a pump replace/rebuild shortly after taking up biodiesel.
    As in my first post, not saying it is a certainty, but it is worth considering.
    Simon
    SA, Newton
    Simon
    Then explain how his would have happened? What properties of Bio diesel would have such an effect?
    its is a surprise considering that many Euro manufactures offer extended warranties on motors which use Bio, yet the same cars in Australia have aussie dealers who slag bio??
    I am referring to Fait, VW and merc ( that I know of)
    Bio and Bio blends are freely available to the point of it is starting to get hard to purchase normal diesel ( in some places), add to that the synthetic diesels available over there.
