Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Thread: Diff Lock in or out on dirt
    Hi All,
    Sounds like a good day on the 22 feb... Anyhow Was told to always put the gear box diff lock in when on dirt..Other wise it wears out faster.. How true is this?? as my disco had no diff lock lever.I have fitted a morse cable to it and now change it from under the lid..er.. bonnet...Just asking...Thanks Bob..
    PS dose anyone know the total weight of a trans.gear box please..
    Ellendale Tasmania.
    I usually put it in, makes the car more controllable, especially in loose dirt.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Melbourne, outer South East
    The boys that know here in Melbourne told me to always engage CDL off the blacktop.
    Adelaide - Torrens Park
    I leave mine out, unless I am in a traction loss situation off road.
    I find with it locked on high speed dirt, the handling tends towards understeer. I prefer a "looser" more oversteery feeling, hence leaving it unlocked.
    mcrover Guest
    Quote Originally Posted by BigJon View Post
    I find the opposite.
    I put mine in pretty much as soon as things get a little loose.
    On shinny dirt roads you can have just as much traction as tar so unless it's wet or loose I dont enguage it.
    It drives a hell of a lot better with it in I find, much more predictable.
    CROMER, NSW
    i was always an outy, bourne fro my days in part time 4wds, but when suggested by a mate whose opinion i trusted to lock it up, i tried it and found it was a heap more controllable.
    i doubt the wear thing would have much creedance. it might be something that has come from jeep circles, they have a similar set up in the quadratrac transfer cases but where ours are open when unlocked, theirs are limited slip and do wear out.
    i found this out from owning a renegade that some knob had blown the front diff in, and replaced it with one that was a different ratio, something had to give and it was the transfer case.
    LAND ROVER;
    HELPING PUT OIL BACK IN THE GROUND FOR 70 YEARS
    CARS DON'T GET ANY "GREENER" THAT.
    Aug 2008
    Victor Harbor SA
    Don't they 'wind up' in the case if there's not enough loss of traction? I've heard stories of people having to back up a long way before they were able to disengage.
    99.87 MB
    WRT to wear, as I understood it from the US, the LT230 is really poorly lubricated within the cross gears in the centre diff, and it is these that wear badly if the CDL isn't locked. I have seen pictures of these blued. I don't know how this applies to the LT95 but John Lee and Ho Chung were adamant that the CDL should be locked as soon as you hit dirt.
    Personally..... with my setup CDL is locked when I go into low range.
    Slunnie
    99.87 MB
    Quote Originally Posted by omvanders View Post
    Yes, but they are designed to cope with that. Wind up has to occur whenever you lock the CDL. The box is pretty strong so I wouldn't worry about it breaking.
    There is only so much windup a box can have, so its more a question of the wind up pressure rather than it winding up like the spring in a wind up toy. If its not unlocking then drive turning the wheel left to right etc, or put the handbrake on and apply drive pressure against it in either direction. These techniques will release the pressure from the locking mechanism to unlock it.
    Slunnie
    Cape Town
    as a slight aside from the above if I may....
    When I jack up my Defender Puma wheels (any one) I get the wheel spinning back as if there is a slight wind or tension on the drive train.
    When I jacked up the front tyre on my Ser III yesterday with the front hubs unlocked I also noticed the wheel spun from being in some tension.
    Wonder how this is possible??
    Defender Kalahari 2006 (300 TDi)
    2008 Puma 110 - sold
    1973 Ser III 109" - sold
