Results 1 to 10 of 21
Thread: Nokia 6110 thoroughly washed
    NSW , Pennant Hills
    This morning I grabbed my King-G Pants that I wear to work on the Landys and checked side pockets to make sure it's got no coins etc in them , I then took the rest of my clothes and chucked them in the washing machine , after adding detergent I close the front hatch and switch it on , off it went to wash "cycle" , after about 20 minutes or so of Looking around for my Nokia 6110 navigator to make a phone call to my sister , I realised that I've left it in the mobilephone pocket of the Pants
    so I reset the washing machine and drained all the water+detergent mix out of it and re-opened the hatch , took the phone and left it outside to alow it to dry , been a really Hot couple of days , anyhow after I was satisfied that all the water had dried out inside I placed the batteries in it tonite and nothing comes on. do you lot think it's worth getting it repaired?
    Singapore via Melbourne
    rinse the thing with battery water first then pull it apart and try to dry it again - still probably dead, but it can sometimes work... 20 mins in a washing machine is a long time though!
    NSW , Pennant Hills
    Hi Mate ;
    can't pull the thing apart , it's got the Torx looking screws and I don't have anything that small to open it with.
    Warburton, Victoria
    It does not matter how good you clean it out, it wont work.. and when you take it in, they will know in secs its been for a swim...
    Sadly, its stuffed..... Technically speaking...
    NSW , Pennant Hills
    It's been rather difficult to part from my Nokia 6110 , it's been an excellent Phone , but I wanted to hear it from one of you forumites that it's "shagged"
    Dec 2008
    the nokia 6110 (like all nokias) is a piece of poo on reliability terms.. you must be one of the few people that would actually miss thiers.
    For future reference if you or a friend ever washes (or swims) there phone there is chance for saving it here's how. You have to act within 12 hours otherwise the electrical components start to corrode.
    Assuming you have a jewellers set of screw drivers pull it apart carefully (instructions for each phone can always be googled).
    Spray each circuit board out front and back with electrical contact cleaner. allow the parts to dry for a few hours. Re-assemble and enjoy.
    This procedure has saved my friends/families phones many times.
    Ermington, NSW, Au
    Quote Originally Posted by Disco_owner View Post
    Hi Mate ;
    I got a set from Bunnings for less than $10. It's got all the really tiny Torx bits along with flat and phillips. 20 bits plus handle.
    2012 110 Defender
    NSW , Pennant Hills
    Quote Originally Posted by rathies View Post
    Hi Rathies
    mmmm....the Nokia 6110 has been a very reliable phone , I've had no issues with it at all , Soon as i Got the phone I went to Nokia web site and upgraded the Firmware to the latest that Nokia had out for this particular handset , the battery seemed to last a long while before requiring recharging , prior to that I had a Samsung SGH-Z140 Flip type phone and it too has proven to be an excellent/reliable handset , except the battery would not last longer that 2.5 days on standby . and that is the Only reason I switched from it to the Nokia.
    Adelaide - Torrens Park
    the nokia 6110 (like all nokias) is a piece of poo on reliability terms.. .
    Not sure how you come to that conclusion.
    I have run nothing but Nokia phones for the entire time I have had mobiles (15 years or so) and I have had one glitch. Phone internals replaced under warranty at no charge.
    My Nokia N70 usually locks up with the very common white screen of death when switched on. Nokia want $220 to fix it. Not worth it.
