Results 1 to 10 of 23
Thread: Removing Muffler TD5
    Drouin South
    Hi Guys,
    Looking to remove the muffler off the Defender this week some time - is it worth paying someone or is it as easy as grinding it off and sliding some pipe over it with some clamps either end?
    I have been told too keep the muffler by a mate, as l will get over the noise!?
    Also - any warrent implications? Is the Dealer going to go crazy?
    Ta,
    Mike
    2011 DEFENDER 130
    SW of Geelong
    It's probably worth taking it to an exhaust fitter. It would be a pretty easy job for them to do as they have all the gear to flare the ends of the new pipe section. Just tell them to do it in a way that you can easily change it back if you want to.
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Padstow NSW
    Quote Originally Posted by mike_beecham View Post
    Hi Guys,
    Ta,
    Mike
    bet your mate dosent own a TD5! you will hardly notice the difference in tone. its deffinatly not loud.
    my first one i had midas do in about 30min for a total cost of 50bucks.
    cheers phil
    Drouin South
    ...that true. He doesn't drive TD5! haha
    Is it worth doing?
    He told me the turbo will spool up faster (better.)
    Different (louder) exhuast note?
    Worth taking both mufflers out? Effect?
    Ta,
    Mike
    2011 DEFENDER 130
    Feb 2005
    i agre with phil, most exhaust shops will nearly do it on the spot, cost me $40 to remove the muffler, a few months later another $40 to remove the resinator and than six or so months later complete new straight through normal bent exhaust for $200
    i reckon the 30tdi is a little noisey as a straight through
    i know i went the long way around, i removed the muffler because it sounded like a good idea, removed the resinator because i crushed the tail pipe, fitted a nnew system because i needed to install a PTO winch
    Padstow NSW
    td5 are quite different in note to the 300tdi. LRH's 300tdi 3'' straight through you can hear coming 2 blocks away, thats why he's now after a rear muffler
    the td5 with the center removed dosent really get any louder, more of a deeper note. ive removed the rear one on mine but its to loud for me, thats on a 90, shorter system than a 110. ide remove the center, and if your bored one day take the rear one off and see what its like. if its to loud put it back on.
    and yes the turbo dose spool quicker with it removed.
    cheers phil
    Drouin South
    So...
    Does anyone with a TD5 have both the mufflers off? Is it worth doing in term of turbo spool or slight power gain? How noisey?
    Thanks,
    Mike
    2011 DEFENDER 130
    Nov 2006
    Alice Springs, Australia
    I took the centre muffler off my 130 and it made no appeciable noise difference. Turbo does spool up faster though.
    Cheers from the Desert
    Rexy
    2000 130 TD5
    Oil in the Harness, suspension knock, transmission clunk, engine oil leaks, exhaust manifold leaks, centrifugal oil filter stripped bolts, a/c leaks, door leaks, wouldn't trade it for the world
    Drouin South
    Well - l had the center muffler removed today and replaced with some pipe. Certainly notice the turbo spooling up faster. Slight note change when under load at low RPMs. But that is about it.
    What is the exhuast 'note' like with the rear muffler removed?? Anyone?
    Mike
    2011 DEFENDER 130
    Mike
    It's Fanbloodytastic....
