how much higher is the filler
i would imagine you could still fill the diff till it comes out of the filler
I have just fitted one of those SOLID or ROCKBUSTER Dana diff covers to the Salisbury on my County and was wondering if anyone can advise me the correct quantity of oil to put in the diff. The inspection/filler plug is a lot higher on these and I want to raise the level a bit to ensure oil to the stubs/wheel bearings but I am unsure how much is advisable to put in there. Any help appreciated...Brian
The bottom of the filler is about level with the top of the axle tubes. I think this is a bit too high.
without having a look at mine, could you have put it on upside down?
It will only go on 1 way. I am pretty sure someone has talked about the quantity before. I would imagine about a quarter to halfway up the axle tube would be ok. Too much and there is nowhere for expansion to go.
nope...
They are designed for a high pinion diff, so the filler is well above the axle centreline.
The correct quantity for a Sals is approx 2.3 litres, but I fill mine with at least 3 litres so it lubricates all the way down to the wheel bearings too.
I was running probably 3.5 litres for close to 18 months.
Capacities (approx.)* Litres Pints
Front differential .......1.70 3.00
Rear differential
90 Models ................1.70 3.00
110 Models ..............2.26 4.00
Taken from the rave CD.When I did mine the other week I added an extra Liltre 2.7 litres in total to lube the stubs/wheel bearings.
Last edited by MacFamily; 8th January 2009 at 08:46 PM. Reason: Quanities were incorrect.
Aaron & Jacinta
1994 300Tdi Defender
'88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
'85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
'56 SI Ute Cab
