Get your wife to make the marks and supervise the cut![]()
Hi all,
Does anybody know some one who can cut my d2 guards (and doors) to fit 35" tyres?? I do not trust my self and using a lot of self control to stay away from it.
Gold Coast, Bris or northern NSW.
All help is greatly appreciated.
You'll be right. just mark around the wheel arch with a crayon and hit it with the angle grinder. If you're worried about the angle grinder then use a sawzall.
What tyres/rims/lift?
Here is how I did it.
www.slunnie.com :: View topic - Guard cutting for 35's
Slunnie
And heres how I did mine:
Cutting guards on 4 door RRC Instructions
Carlos
1963 Land Rover Series 2a 88
if you are unsure,just cut 20 mm lower than the mark,trial fit and trim again,its not that hard (its just scary to see how much metal you have to remove) just triple check all the measurements..if you are using les richmond xl flares the instructions are relatively straight forward to understand.![]()
Yes seen both your jobs and very impressed.
Slunnie
My lift is only 50mm but will lift to 100mm
Have not picked out tyres yet, running mzt 31.5 at the moment
Rims are pro comp rock crawlers with quite a large off set (tyres just stick out the out side of the flares by 10mm.
Could I fit 34" with out cutting??
thanks both for your help
Mark
discologist,
Did'nt know the flares come with instructions, thanks (still dont want to do it)
Gday Baffle no worries, 100mm will be fine. The real difficulty is making the front work rather than the rear, but even 30mm bump stop spacers will make it work. My front has sagged from 4" down to about 2.5" now and there are no probs.
With the tyres you also need to look at the treadface shape as tyres like the Simex JT2 have quite a broad face, but its also convex, where tyres like the MTZ have a fairly flat treadface and may require a little more cutting to make them work.
The offset definately helps, the implication is that with standard offset the tyre will still tuck into the guard at full compression, where an offset rim will mash through into the guard, and so requires a significanlty bigger cut over the wheel. Flares like the Rangie Spares flares will do this and cover the cut.
Any radial tyre larger than a 285/75-16 or a Simex 33x10.5 needs cutting.
Slunnie
hey slunnie
__________________________________________________ _____________
Any radial tyre larger than a 285/75-15 or a Simex 33x10.5 needs cutting.
Did you mean 285/75-16?
I hope so coz im not too keen on the grinder![]()
