Results 1 to 10 of 12
Thread: Td5 and 'that bolt'
    here
    Td5 and 'that bolt'
    Well I dropped the sump today to check that bolt. NO LOCTITE
    I am ever so glad I did it and thank the gents that attended Scouses' Jenolan cruise.
    Whilst the bolt wasn't loose, it did not take all that much effort to loosen. Loose enough to be a risk in my opinion....anyway, all fixed now.
    FYI - My Disco was manufactured 10/03, and again, had NO LOCTITE
    I think that EVERY Td5 should be checked. If you are unsure how, then ask me as I have now done one so I am of course, an expert
    Caine
    Yass NSW
    Glad you caught it.
    Took me 6 months after doing mine to stop getting nervouse. I kept wanting to go and check it again everytime I started the engine.
    Oct 2007
    TD5 Bolt
    Now! that is a worry! I thought that the problem was sorted at least by early 2002,now we seem to be having later models with the same issue.
    My Disco is a 06 2001 and it has been checked because that was in the region of concern. As it turned out mine was O.K.but 2003?obviously still an issue.
    Why didn`t they put on a lock tab or wire the bloody thing in the first place?
    Trev.
    here
    Hi trev,
    yeah I thought I was immune as I owned an '03. I hadn't read any '03 Td5 bolts without the loctite.....but there it is. I can confirm this is not the case and I would say that 'ALL' need to be checked as a matter of urgency.
    And as I said, I wasn't going to even check it until I went 4x4'ing with Scouse.
    Caine
    Williams West Aust
    A good news story for a change.
    If a left handed thread was used it would never have been an issue.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    NSW SW Slopes
    I'm sure there was a post quite some time ago re 2 Defenders being checked on the same day and the '03 had a suspect bolt whereas the earlier one was OK.
    Jan 2008
    4510 QLD
    Caine, you have made me nervous.
    Maybe the design of the bolt was changed in the later models so Locktite is not mandatory?
    here
    Might have been. Not sure.
    Either way, DO IT.
    South West of Brisbane Qld
    I did mine about three months ago mine a 01 model was not tight or loose just in limbo land glad i did it in time had about 125000 on the clock **** of a job to do as i left the gasket hanging an a nail in the shed for three months it was a little distorted at the time of installation
    NSW SW Slopes
    Quote Originally Posted by jmkoffice View Post
    Mine's an 03 and the new bolt had Loctite already applied.
