 Fossicker
						Fossicker
						G'day All!
I recently bought my self a 200tdi defender and I got the timing belt done a week ago and it's gone really badly since then. I think the belt must of gone on wrongly.... Will bring it back to who did it tomorrow.
But even before it was done it would not sit on 100km/h very well and I was just wondering how well other peoples 200tdi defenders go!?
Ben
 Fossicker
						Fossicker
						So would you say that you should be able to cruise at 100km/h ok!?
Are you kidding??? Flat throttle it should see 130Kmh easily. 100km/hr is a cinch when they are set up right, and at that speed cruising you should see 10 to 11 litres/ 100km fuel consumption too.(27 to 28 MPG)
I must add that valve clearances are critical on ALL Tdi engines for good performance. .008" (.208mm) hot or cold, inlet and exhaust, checked every 10,000 to 15,000 Km.
This IS important, as they can pick up as much as a WHOLE GEAR up hills when the valves are adjusted right.
JC
 Fossicker
						Fossicker
						Nah I was not kidding!I am glad to hear that they should go a lot better then what mine is doing! But my only concern that there might be some thing wrong with mine. It has only done 220000kms so I would assume that it would still be good!
Thanks for you help mate!
Might get him to give you a call tomorrow.
Ben
 Fossicker
						Fossicker
						oh yeah would it be worth bringing the car to a diesel specialist or land rover place to get the engine set up right!?
 Fossicker
						Fossicker
						I am in Maleny in QLD and Brittish off road is just down the road and Allan Jennings isn't too far away either.... But I have no money after the timing belt being done and the steering box went on it in the same week!
 Fossicker
						Fossicker
						My 200 TDI discovery sits on 100- 110 klm all day every day and it does it easily. I have had it up to 130 klm per hour but it does not feel comfortable at this speed. 110 is a nice speed but it tends to go through the juice at a far greater rate than 100. On the open road I get around 750-800 klms per tank. not sure if that's good or bad but I'm happy with that.
Guy
