Results 1 to 9 of 9
Thread: relays in engine fuse box
    May 2008
    On my '99 4.0 I noticed that the green 5-pin relay in position RL10 is missing.
    According to RAVE, on the 99 model RL10 is for the Secondary Air Injection Pump Relay which seems to be a useful thing to have when the engine is warming up.
    Will an 5-pin relay from Repco, SuperCheap or JayCar be a suitable replacement for the green 5-pin relay or is it a LR specific part? Same goes for the yellow 4-pin relays. I doubt that it is LR specific, but wanted to check with you folks first.
    Thanks, Paul.
    Nov 2006
    narellan, sydney
    I have always been told that landrover ones (siemens brand) are rated at 30 amp. I dont see any problem with using any other brand aslong as the rating is the same. (It Might pay to email the previous owner to see if he took it out for a reason though)
    Andy
    Douglas Park, NSW
    Quote Originally Posted by PaulP38a View Post
    It might be useful.........if it was fitted.
    Australian spec cars didn't have secondary air injection.
    Sounds like a good spot for a spare relay though .
    Hi Paul,
    Yes LR relays on the P38 ARE vehicle/color/engine specific & a standard relay will not fit. The pins are different & can/have caused damage to the BECM..Not good. BECM's arent cheap.
    So please be careful.
    May 2008
    Thanks Scouse.
    There you go - I learn something new every day
    Now to get some spare relays - a few of mine have burn marks that don't look very healthy. Maybe a new fuse box for good measure too.
    Hi Paul,
    A spare fuse box is a good thing. With the amount of heat build up under the bonnet the fuse boxes tend to crack the circuit board in them, which can lead to all sorts of malfunctions & lights displaying on the dash.
    If u can see signs of burn marks on the relay tops..I would definately change the fuse box also. Bit of preventative maintenance & also makes the vehicle more reliable.
    May 2009
    a
    paul,
    their are lots of relays that are compatable with the range rover at any auto store just check the circuit driagram. but i use yellow- bosh 0332 019 457 green- bosh 0332 209 150. I change the whole lot and kept the origonal ones as spares, not failed yet 2 years ago.
    For info:
    I recently (6 weeks ago) imported a genuine P38a MY2000 fuse box from Brit Parts. It and came loaded with all fuses plus spares but no relays.
    I also ordered a stack of yellow and green relays. The relays were a touch under A$10 each and the fuse box was A$194. DHL delivered the lot to the door from the UK within 5 working days of placing the order for about $30.
    The original fuse box was 9 yrs old and was stuffed... cracked and burned around Relay #7 position. Several (yellow) relays had dark brown telltale burn marks.
    dismantled the old box (couldn't help myself )
    It is a complex " two storey" PCB with a flexible conductor running the length of one side joining both boards. Additional "direct" connections are evident between the solder sides which are internally facing a few mm apart. They are jam packed with push fit connectors for fuses and relays which as expected are themselves interconnected... I put it in the bin
    I repaired mine and wrote it up here: Fuse Box Repairs
    Pity you've tossed the old one out.
