Results 1 to 9 of 9
Thread: Stuck ashtray and coin trays in DII
    May 2008
    Camp Hill, Brisbane
    Anyone had this problem? Can't seem to release them by pushing in further or pulling from underneath.
    TIA
    Steve
    Apr 2007
    Prospect SA
    Had similar problem.
    Get a knife and try harder,worked for me.
    Rayngie Guest
    I happen to be an expert in two such matters, this is one of them,this happens to me at least once a week ( Sold the D2 thought so won't be a prob anymore! ), get your fingernails up underneath it at the very back, thumb on the front, sort of push it up with thumb, and out with fingernails, should come out easy.
    If not, you're buggered.
    Also have the worlds best hiccup cure if needed.....( that's the other matter )
    Ray,
    i think he's got it.
    otherwise, just drop down to the neaest supermarket complex near you and ask a kid that looks like a 'doof doof' car is his home, or is wearing his hat backwards, to open it for you.
    Safe Travels
    harry
    Ermington, NSW, Au
    A selection of swear words and rapid "tapping" with a closed fist to settle the contants worked for me.
    2012 110 Defender
    mike 90 RR Guest
    ash tray & coin box stuck ?
    Naaaa
    It's a built in anti smoking devise & a money safe all in one
    DM74 Guest
    Hi guys,
    can anyone help here?
    I've removed the cup/coin holder assembly and found out why the ashtray wouldnt spring out - no spring! Broken plastic lug but I found the spring behind the console - lucky me!
    Of course on removal, the coin holder side broke so now I need to fix both!
    Is there a later model with a better design? (mines early 01') The spring tension is considerable when the trays are pushed in - no wonder the plastic bits broke!
    Is there a good 'fix' other owners have found?
    Thanks for any help,
    Darian
    Melbourne, AU
    Had the broken spring tab on both of mine. Used a small nut and bolt with washers to capture the end of the spring and drilled thru the plastic casing. Seems to have worked for the past months.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    Jul 2009
    Lake Macquarie NSW
    My coin tray was stuck in. Spring came off and plasticy thingy broke. I just pull/push it manually.
    Regards Robbo
