Page 1 of 7 123 ... LastLast
Results 1 to 10 of 66
Thread: D1 300tdi build up
    Jul 2008
    D1 300tdi build up
    Well it all starts here in december 2008 i landed myself a disco
    its a 95 300tdi auto 130ks
    old mans beige with tan interior
    got it bog stock with some work that needed to be done for $5800
    Hobart Tasmania
    Pics?
    Carlos
    1963 Land Rover Series 2a 88
    Wollongong
    Thats not a bad buy, gives you plenty of options to personalize the vehicle to your own taste.
    I just bought a 98 man 300tdi with 180,000 for just over $12,000 but it doesn't need anything done to it, came with bull bar, tow bar, driving lights, up graded suspension, 120 lt fuel tank, UHF radio etc. Anything else I need I will take off the other one I have before I sell it.
    Jul 2007
    jeep boy,
    you done good.
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Jul 2008
    pics are here and are more details of what i been up to on it
    as soon as i got it a put a new header tank in as the old one was cracked in the hole on the top of it
    got the tank and cap forr a $100
    than chnged the oil and filter, put injector cleaner in and a new air filter
    by this stage it was going so much better than the day i bought it
    Jul 2008
    a few things i kept from the jeep was
    fridgemate fridge
    otima big blue top
    gme tx 3400
    so i put the optima in it was a tight squeeze and had to make up a bracket to hold it in but it worked a treat
    pic here when it works
    got a smart solenoid from arb and it works great, i earthed it when putting it in and it wasnt working on its own so i set up an override fora few days than took the overide off and it worked how it should
    than i put my uhf in i mounted the main unit up under the steering colum and the head unit works a treat here
    Jul 2008
    the gme tx3400 is great with the hed unit it makes it so easy to find a place to put it, the main unit is near the steering colum, and the head unit is great where it is
    the tires took some triiming to fit but they got there
    fitting the optima was a close one it only just fits in but damm its a good battery has never let me down and the isolator from arb works great to, i couldent buy holer for it so i made one up put of rhs and it is better than a bought one
    may as well put up a pic of my jeep i sold as we are about to have a baby the jeep just wont work hence buying the disco, the jeep was a dream i had since i was about 12 and it took a lot for me to part with it
    Jul 2008
    well i got bored today and last weekend i re-arenged the gay plastic section on the front bar so i kinda removed it, looks much better
    Jul 2008
    been thinking about a cargo barrier, and want to know peoples thoughts on one out of a different car fitting, can one be modified or used and still be safe,
    how do they normally mount into the car to hold so much pressure, im going to be settin up some draws nest to the fridge, with a middle section for the space case, and a section up top for lightweight things, simillar design to waht you see outback advertising
