Results 1 to 10 of 33
Thread: P38 ride - it seems hard and jiggly
    Jul 2008
    Geelong Victoria
    G'day guys,
    I have been noticing that the ride on my 99 P38 is pretty hard. Its certainly much harder than the 95 VW Caravelle that we have as a family car.
    I had a look under the car and everything seems to be stock. The shockies appear to be OEM - they are black in colour. The airbags appear to be OEM also. The only thing I can think of is that the tyres are LT (light Truck) tyres.
    Any ideas or comments?
    Willem
    mike 90 RR Guest
    High tyre pressure will give this effect
    What tyre branding / size are you running?? as LT tyres have more ply ratings to the side walls ... reducing side wall flex
    Mike
    Jul 2008
    Geelong Victoria
    Quote Originally Posted by mike 90 RR View Post
    Mike
    G'day Mike,
    Fair comment. I am running Bridgestone Desert Dueler 682 Light Truck 22/75R16 at 30 PSI.
    Willem
    Quote Originally Posted by willem View Post
    G'day Mike,
    Front or rear?
    I run stock 28 front, 38 rear with the Cooper ST. I ran the same with the Michelin XP.
    mike 90 RR Guest
    Your car should float with the right shockies & tyres
    Are there ... and what are the coloured stripes of ID paint on the front springs?
    So it's this Tyre your using?
    D682
    Ron or others should be able to advise further
    The springs are rubber bellows. It has air suspension.
    mike 90 RR Guest
    Ohh ... Front air bags instead of springs ... this is why I try to keep out of this (P38) section
    Mate! If you never, never go, you'll never, never know!
    mike 90 RR Guest
    I keep a eye on these section's cause sooner or later I will be owning either a Late model P38a or a early L322 .... so I'm taking in "the good oil" beforehand
    Anyway .... thoughts on why Willem has a hard ride instead of a floater?
    None, I'm afraid.
    I know my P38A is much smoother than our D1 was (and other D1s I've driven). Willem didn't mention it when he was here and he drove mine.
    I can only think of shock absorbers being the problem (assuming the car is not in extended mode).
