Bleed what part? Fuel, coolant, brakes, power steering??
g'day guys just wondering if anybody knows how to bleed a p38a??? i have heared that there is a specific way??? please an help would be app.
cheers simon
I think it's the Coolant
He's been having cooling issues ... I have advised him to
Rod the radiator
Change the Thermostat
Fill with coolant in the correct fill procedure ... to remove any air locks
Hopefully he has done the first 2 properly
Anyone know how to do the "fill the coolant procedure" on the P38??
rangiep38
quote
"i have heared that there is a specific way???"
There sure is......too long for here..........buy a copy of inc.'s rave CD off this site and a pressure bleeder !
Click Here For More
The main thing is to disconnect the small hose from the top left hand side of the radiator and blow out any coolant before you start. The air lock forms if there is coolant stuck in this line as it is the breather between the radiator and overflow tank.
I have also installed a TEFBA coolant filter Tefba Filter Radiator Filter - radiator insurance Australia
on mine which gives added protection and makes it easier to fill up.
2011 Range Rover Sport SDV6 Autobiography
2004 Freelander TD4 SE
1997 Range Rover 4.6 HSE
1994 Range Rover Vogue
