I have the chance to buy some 130 Rims ( the ones with the holes in ) iam told they need tubes and the most common way to do this is to fit si discovery rims??? does this make sence??
if you use the search function you'll find several related threads on this;
Running tubeless on tube type rims
while I have never had a problem with tubeless tyres on LR tube-type rims, it is said to be something of a "no-no" for some people & tyre fitters
oh yes.....
and I've seen quite a few 130s using D1 steel rims
so no really answer as to if you can or cant??? I was told tubless 130 rims are very rare, to buy new.
the real answer is that you can run tubeless on tube-type rims .... but you might have to fit them yourself
the big advantage as I see it is that if you run tubeless, then you'll have fewer punctures and those that you do have will usually be repairable without removing the tyre from the rim
... (wait for the bush lawyers & rulekeepers to strike)![]()
The ones in the picture i put on, are they in 2 parts?????
...um...(assuming that you mean split-rims) the ones pictured are not split-rims
yes the ones in the picture, i think i sort of understand this wheel stuff, wolf and 130 rims are the same.
but most rims regardless of the style are tubed, ie the ones in the picture, and the ones fitted to pre 96 defender 130s
