Results 1 to 6 of 6
Thread: LCD screens,
    May 2003
    On The Road
    LCD screens,
    I've been looking at 24" LCD monitors and they dont seem to vary much,,
    this is an example,,
    The (ACER) P244WB LCD monitor is designed for users who require exceptional performance, presenting intense graphics and superb video. The striking, shiny black bezel complemented by a polished black base and gleaming silver arm reflects understated elegance.
    Features
    • Colour: Black
    • Display Size: 24” Wide, 547 x 352mm
    • Dot Pitch: 0.276mm
    • Resolution: 1920 x 1080
    • Brightness: 300 nits cd/ m2
    • Contrast Ratio: 20000:1 (ACM)
    • Maximum Refresh Rate: 1920 x 1080 @ 75Hz
    • Viewing Angle: 170° (H), 160° (V)
    • Response Time: 2ms GTG
    • Input Signal: VGA (Analog D-sub)+ 2 x HDMI
    • Speaker: None
    • Power Adaptor: Internal
    • Power Consumption: <75W
    • Kensington Lock: Supported
    • Pivot: NA
    • Height Adjustable: NA
    • Weight and Dimensions: 7kg, 569 x 418 x 207 mm
    only a few things seem to vary,,
    response speed 2 or 5 ms
    max resolution 1900 by 1080/1200
    most seem to have the same contrast ratio
    and dot pitch.
    do all the screens come from the same factory?
    just speed-binned?
    will length of warranty be a deciding factor?
    yes it will be used for games,, ( the purchasing criteria will be weighed heavily towards performance) but unlike tombie,,,
    serious games,,
    and at 4-500 a pop,,
    a serious request for info,,
    Avoca Beach
    Hope its not for the car.
    Would take up a bit of space on the dash.
    Regard sPhilip A
    There's not that many manufacturers: Sony had (a few years back) outsourced all screen manufacturing to Samsung, Philips is all made by LG, Lowe and many others by Sharp, Hitachi and Fujitsu had a joint plant, Toshiba and NEC, etc.
    It also gets a little more in bread when you narrow down to a particular LCD panel size. When 24" first hit the market there was only one or two manufacturers of the actual panels. Didn't mater which brand you bought really.
    Often the key differences are in the additional circuitry. This is particularly obvious in TV receivers like the Sharp and Lowe but not always as obvious in the monitors.
    Also Acer, Dell, HP, Apple etc don't make their own monitors anyway so they design a casing and put their brand on it.
    If you want a really good monitor look at Eizo.
    Nov 2008
    there is a cople of things i can say to this,, an yes i play games an build my own pc from the ground up, if it was me an i have been there befor,, i wouldent realy bother with a 24", an pay the little bit more for the 27", alot better looking, an a lot more crisp, cos iv gone from a 19-22-27" lcd, an the 22 is great at a great price, but for pormance a 27" you cant beat,
    the next thing is do you have a pc that will run that res, an at a deacent FPS, the worse thing in the world is playing a game an it looks like a power point slide, 1920-1080 is a very high res, an will take a lot of pc power to run it smothly,
    once you have it you will never go back
    what system are you running
    May 2003
    On The Road
    good enough to play Crysis with nearly everything maxed.
    I think the box will run it ok,,,
    Nov 2008
    oh realy,, but what res are you running at the moment, on my 27 i can play that will all most everything on max(no AA) that realy kills it,, an you can here my water cooled CPU an GPUs boling water
