Results 1 to 10 of 17
Thread: which d1 parts can be used on a d2?
    Apr 2007
    Hi fellow LRD lovers
    my d1 has died over the 40 degree days the engine overheated and now the repair costs dont justify themselves
    so.
    i upgraded :-)
    i now have a 2000 model d2!
    love it!
    onroad, but i feel that offroad, its not as capable as my d1
    before i dispose of the d1
    is there anything i should rip off it so i can keep as parts, ie, alternator, etc.
    or is there anythign i can use to retro fit to a d2, ie, CDL components?
    any help/advise would be great!
    thanks!!!
    anyone need parts off a d1?
    everything was in working order other then the cruise control (myd2 one doesnt work either)
    and the engine is not in good shape, but all the bits are fine,
    new alternator, new master brake cylinder, water overflow.
    Nov 2008
    Ingleburn, NSW
    There are a few bits i'd like to replace on my d1, where abouts are you?
    99.87 MB
    I think that you'll find it a lot more capable offroad.
    Slunnie
    Aug 2008
    Sorry I have no idea what parts fit on a D2 as I don't have one, but where are you as I might want some D1 parts?
    May 2008
    Horsley Park, Sydney
    Hi, there are few similarities in the 2 models - there are some
    To my knowledge the following are interchangable from the D1 to the D2
    The rotary coupler under the steering wheel is the same for all airbag models
    The dash surround and dash vents are the same for VIN MA models onward
    The high and low pitch horns
    The front window winders are the same from mid 1995 onward
    The handbrake - not handbrake cable
    The cruise control vacuum pump and bellows for petrol models
    The inertia relay (slightly different mounts)
    The rear tail shaft
    The heater core and a/c evapourator VIN MA onwards
    The light switch / indicator wiper switch VIN MA onwards (airbag models)
    24 spline diffs ???
    Late model LT 230 (with the cross drilled gear) ???
    3.9 and 4l starter are interchangable as are numerous engine components. Many switches appear the same but have different plugs.
    There are probably more
    Erich.
    mcrover Guest
    V8 or diesel, and where are you.
    Quote Originally Posted by turbo6i View Post
    so.
    i upgraded :-)
    love it!
    thanks!!!
    As long as they are both Auto's or manuals, If not you need to buy the mounting bracket for the lever assy, and the CDL lever that comes of the actual shifter down to the transfer case as the Auto and manual use different ones. It can be done, but tbh its more hassle than its worth. The "04" linkage assy is far easier to use and a LOT quieter in the cabin to.
    Daisy Hill Queensland
    If your D1 has the twin UJ tail shaft, swap over that, also diff centres can be swapped but not the housings
    The rear (cargo) door is the only panel that carried over.
    Head lights on late d1's, just got to do both
    :TakeABow:LAND ROVER
    Don't Follow Me, I'm in a "Land Rover", You WON'T make it.
    aut viam inveniam aut faciam
    Apr 2007
    Hi people,thanks for the reply
    my old car is 1994 Discovery 1 with the updated interior, almost similar to the d2.
    it is an automatic petrol, and everything other then the cruise control worked a treat on it before the engine caput.
    in the last 6 months i have put a original landrover alternator on it, a water tank resivior, and a master brake cylinder.
    its got a 3 inch lift suspension, spring and shocker lift. 8 or so months old.
    was a perfect car up until the engine overheat.
    it is up for sale.
    i am located 5 minutes from melbourne central.
    it has a full set of bf goodridge mud tyres.
    i may put them on my d2, which has an almost new set of michelin tyres (up for sale)
    my new d2 is manual, and i'm thinking of striping my d1 of all the parts that i can use on the d2 before i give it to a wrecker.
    does anyone know if the d2 manual uses a compatble cdl system to the automatic d1?
    regards
    sundeep
    0488990100
    feel free to call me if you can get thru
    otherwise try again in 15 minutes
    Apr 2007
    Quote Originally Posted by nice1guv View Post
    hi
    i make a trip or two to perth every year
    what do you need ?
    i can pack it next trip.
    can do you half of what your best deal is
